Tubing notcher
Discussion in 'The Garage' started by Mobile_Mechanic, Mar 25, 2002.
  1. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    I'm looking for a decent notcher to help with my fabrication. Tired of using my grinder. Need it for up to 3 to 3.5" for roll cage, rock sliders, ect... Any ideas?
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Harbor Freight???
  3. Mobile_Mechanic
    Jul 17, 2001
    88
    Phillipsburg, NJ
    Harbor freight only lists 3. And they only go to 2 ". pretty cheap though. The most expensive was $70.00.
  4. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    the one from harbor freight lasted me one day,the bushing went fast it was still better than grinding
  5. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Try WIlliamsLowBuckTools.com?......or maybe it's just LowBuckTools.com?
    Anyway, they've got notchers.....and not just those dangerours "hole saw" style ones......check 'em out! /forums/images/icons/smile.gif
  6. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    it would seem to me, that getting a drill press, with a vice, and a set of hole saws going up to the size you need would be the way to go with this... plus, then you've got a drill press to boot.
    -Rich
  7. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yard sales.... if you got time check into them. I find cool stuff every so often. I got a tube bender once for cheap, however it got stolen, but still it was an awesome deal. Also if you have any local flea markets where people can sell their stuff like a yard sale look into that.... it's a shot in the dark but you never know....
  8. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I don't think the hole saw notchers will notch tube bigger than 2" probably because most tube benders don't bend tube bigger than 2". I have one from <a target="_blank" href=http://www.jd2.com>www.jd2.com</a>. It wasn't cheap, but it has a sealed bearing, and will last a lot longer than the ones with bushings (harbor freight). You basically get what you pay for with notchers. I've built 6 bumpers with mine so far, and been through 10 hole saws with not a single problem from the notcher.
    BIGJ
  9. Mobile_Mechanic
    Jul 17, 2001
    88
    Phillipsburg, NJ
    Great info, thanks. I noticed that the notchers you guys listed only went to 2", would this be big enough for a roll bar? Double hoop with single kickers or should I go with 3" and use the grinder?
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    IMO 2 x .120 HREW is generally considered more than adequate for a full size cage in a rock crawler. If you do sand or Baja type stuff, you probably want to go smaller and stronger with DOM or Molly for weight savings AND the ability to hold up to 70+ mph rolls. If your talking just "roll bar" then I don't know about that. Most "roll bars" are really just fancy light hangers and, while better than nothing, are not designed to be "used" in a roll over. If your trying to build a stronger “roll bar” that would actually be semi-functional then I would go ahead and get a cage. Not that much more trouble, and MUCH more functional. Heck, you can buy a pre-bent cage from S&amp;W now for what a decent roll bar will cost.
    Edit: Oops, just reread your original post. Looks like you are talking about a cage after all and probably not interested in buying a S&amp;W. 3" is way too big IMO. I'm leaning hard toward 1.75 x .120 to build a cage for myself.
  11. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    3" roll cage? I've never seen anyone use 3" before. Duno if it is weeker or what but most are 1"3/4 rolled steel(seamless).
    Good Luck
  12. Mobile_Mechanic
    Jul 17, 2001
    88
    Phillipsburg, NJ
    Sorry, I should have been more specific. What I want to do is put a roll bar in the bed of my pick-up, and later install a cage inside the cab. I know to tie it into the frame for optimum performance and all, just looking for an easier way to weld it together.
  13. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    i dont think that attaching it to the frame would be the best thing to do. if that cab and frame seperate youre stuck in the middle!
  14. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    BadDod...What does S&amp;W stand for? Would like to know where to purchase a good cage but don't know who your talking about. Gary
  15. chris672
    chris672 1/2 ton status
    Jan 25, 2002
    554
    LODI, CA
