Tubular steering Tierod
Discussion in 'The Garage' started by RocKKer, Apr 11, 2005.
  1. RocKKer
    RocKKer Newbie
    Apr 10, 2005
    4
    California
    I have a 90 Blazer fullsize, 4" lift, 10 bolt - detroit front, 33X12.5 15 - 8 lug conversion, 14bff rear, 250K total - less on running gear.
    I just noticed the left side ball joints are loose as well as the left end of the steering tierod.
    I read the ball joint posts and will be doing that this week.
    I have a question about the tierod, almost $100 for a new left end (drivers side - the long end). I was thinking of replacing it with an aftermarket tubular tierod and using replaceable tierod ends for a little more ($85 + whatever a new end costs) and I like the idea that the both ends now would be replaceable. I can use the right side end for now, as it seems ok. This is my everyday driver so I don't think I want heim's.
    I have seen one at offroad design, so I'd be lookin for something similar.
    Here is one at Offroaddesign
    Not sure what to do about the steering stabilizer because on the original it bolts to a hole in the tierod.
    Does this sound like a good upgrade?
    What are some other manufacturer of tubular tierods? I do like the offroaddesign stuff, I have some of their other stuff and they seem to be good.
    Edit: corrected spelling :blush:
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    ORD's stuff is always nice....
    I bought a RockRod from Rockstomper about 4 years ago and it was really nice also. Last time I talked to Scott at Rockstomper, he was holding off on the RockRods due to steel prices. But give him a call, because things may have changed.
    With the aftermarket tie rods, you buy a bracket that bolts onto the tierod via some u-bolts and then use the factory stab mount on the axle tube....
    There is a write up in the product reviews on the main page here where Steve installed a RockRod with 1 ton tie rod ends. Nice upgrade and a good investment! :thumb:
  3. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    MO Offroad also makes a nice product...
    http://www.mo-offroad.com/TieRods01.html
    I have posted up about other Al options but that was pretty heavily frowned upon. Most guys say to stick with the thick DOM tubing.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I can't help much on the aftermarket steering, but the factory piece at PartsAmerica is only $44.73, part #DS893
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
  6. RocKKer
    RocKKer Newbie
    Apr 10, 2005
    4
    California
    Appreciate all the posts!
    Tomorrow I will call the links that were given and get more info.
    I looked at the review here on the rockstomper install - that will make it easy.
    Another question - there are lifetime tierod ends and non lifetime - but you pay over double the cost for lifetime, $25 compared to $65. Is it worth getting the lifetimes for a somewhat easily replaceable item?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got my lifetime warranty tierod ends from Checker Auto parts for $26 each.
  8. RocKKer
    RocKKer Newbie
    Apr 10, 2005
    4
    California
    Done with balljoints on the left side and got my new steering tierod. Will do the right side at a later time. Left was loose and right is ok for now.
    I went with WFO for the steering tierod - they happened to be inexpensive and only 30 minutes away from my house. I was kinda in a hurry anyway - needed to be done for a trip this weekend.
    I called WFO and talked to Trevor yesterday afternoon, he asked for a measure and he said he'd make it and be ready the next day. I went there this morning and true to his word, it was done. Paid the man took it home and installed.
    As far as steering rods go this is a beautiful thing, Workmanship is first class! Thanks Trevor! :D
    New balljoints and a new tierod sure make a big difference! It's like driving a new truck.
