Tuff Country EZ ride lift ordering info
Discussion in 'The Garage' started by mr.smartass, Jun 19, 2005.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    i just finished my electric fan setup and i've ordered body lift and now i want to order my suspension lift, i have an 89 half ton k5, i want a 4" tuff country ez ride lift, springs all the way around, all i need is the part numbers for the springs and a cheap/best place to order them from. And a quick check on what else i need, longer brake lines (brake lines from an 88 chevy 2wd pick will work right?), dropped pitman arm, anything else??? any tips for installing either the body or suspension lifts? and since i'm not going with blocks will i need something to correct the driveshaft angle or what? i'd like to get started as soon as possible because it's hard to find time to work on it. any help is appreciated thanks fellas.
  2. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    K, I just ordered a 2" suspension lift from them. Do I need a dropped pitman arm???
  3. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    oh yeah and longer shocks... i don't really know... i was wondering if i order all this seperately or is there a kit? most the kits i've seen were high and i figured i could just order the parts i needed for cheaper, like the shocks and brake lines i can get from the store i work at for my cost. and usually you need either a drop pitman arm or a raised steering arm but i think the pitman is the better way to go if i'm not mistaken... hopefully someone will chime in soon.
  4. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    I know you'll need those longer shocks. I got the 2" from TC for a pretty ok deal... they're good too I hear
  5. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
