Tuff Country Rear Springs Help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Todd78/87, Apr 4, 2000.
  1. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    Haines, Ak
    Any of you with a 3+" TC lift? Did you get wedges with your kit? Or did you need wedges? I called them and asked if the longer part of the spring goes to the front or rear,, they told me to the rear. I couldn't get them to line up, so I flipped them around and they lined right up. But now the rear axle is actually rotated forward a bit,, seems like they are on backwards, but I couldn't get them on the other way. Should I just leave them and find some wedges to put between the springs and axle? I lowerd the xfer case and it helped a lot, but I still have a vibration because the bad angle is from the rear axle to the driveshaft.
    Todd 78/87[​IMG]
    Alaska Bound
