Tuff Country springs... help!!
Discussion in 'OffRoad Design' started by Topdown, Jan 28, 2003.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Ok...I bought a set of 4" TC springs and a 1" zero for the rear and a set of 4" front TC springs. after getting the zero and the rears installed, all looks great! I then install the fronts and POW... the K5 sits about 2" taller in front than rear... did I get 6" fronts? I cant find any stampings on the springs to tell me what part # they are. all I have is the sticker on the top of the leaf. (TCI-CX4M) Help... this will make weekday #2 and day 4 total that the K5 has been in the garage (1-full day searching for U-bolts because I forgot to order them)
    Should I use a 2" front spring for a 4" rear?
    Should I use a 6" rear for a 4" front?
    Did I just get the wrong spring and am freaking out for no good reason? /forums/images/graemlins/crazy.gif
    help?
    -Ryan /forums/images/graemlins/k5.gif
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Just to get the question out of the way: Did you preload the bushings? i.e. tighten the spring bolts to spec prior putting the weight of the vehicle on the springs. My 2" lift HD springs actually netted me about 3.5".
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Check the part # on the rear springs, the fronts are right. Actual lift can vary depending on a lot of factors but you should be closer than that.
  4. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    whats so wrong with a 2" height diff? my sub has about that much and i like the way it looks! /forums/images/graemlins/confused.gif
  5. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    Scott
    Is there any reason other than a personal style choice to have the rear sag on your burb (lower center of gravity)? I havent gotten the physics of CG figured out yet (per the arcane formulas someone posted a thread in the garage) but I would think lower is lower.
    I love to put heavy stuff (lumber, cement, bricks, huge storm-felled log rounds) in the back of mine and am gonna do my da*ndest to keep the rear a bit higher than the front when I lift mine, unless you got some logic for keeping it lower at which point I would have to start doing some more thinking.
    Ben
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    You might want to go with the lower rate springs for ride quality and ad a rear air bag set for hauling heavy load or pulling a trailer when needed. /forums/images/graemlins/thumb.gif
  7. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    2'' of height difference... HAH!! my /forums/images/graemlins/k5.gif has been sporting the prerunner/ saggy ass stance for over a year, it started at 6'' lower, then 7'' /forums/images/graemlins/shocked.gif, then 5'' and now 2 5/8'' /forums/images/graemlins/cool.gif. I have noticed better landings from big air with the ass end lower, it seems to shift more weight to the rear thus creating better balance. Also equals more broken rear axles /forums/images/graemlins/wink.gif The look works for me, butttttt.... I am getting tired of dragging ass over every ledge I drop off of, I think removing weight from the front end to balance it out would be the better approach. BTW hauling anything more than my spare tire and a couple of passengers is a no no in my /forums/images/graemlins/k5.gif
  8. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    Bruce
    I'm not sure what you mean by the rear air bag set. You messing w/ me? /forums/images/graemlins/laugh.gif
    Ben
  9. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    Jay
    If I ever catch serious air in my /forums/images/graemlins/burb.gif, I'll be sure to post a thread on it. /forums/images/graemlins/laugh.gif
    I never consider the prospect of lower rear stance for landings - that would probably make tippage a whole lot less likely, eh? Me, I try to personally keep as many wheels on the ground at all times, but I'm not a flight instructor. /forums/images/graemlins/laugh.gif
    Ben
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I mean something like this... [​IMG] /forums/images/graemlins/thumb.gif
  11. bpiccioni
    Aug 11, 2002
    187
    Eugene, OR
    Bruce
    Thanks for the clarification! /forums/images/graemlins/thumb.gif You've given me a whole new way to lose sleep tonight - on Air Lift's website! For a while there it seemed like I might not have anything to do!
    Ben
  12. Topdown
    Nov 26, 2002
    2,598
    you are right... the fronts are the correct springs, but the rears are/were wrong... easy enough to fix. I took out some 3" blocks, I will just put em back in!
    Thanks Stephen! /forums/images/graemlins/thumb.gif
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm guessing that you didn't buy them here since I can't find your name anywhere but what about talking to whoever did sell you the springs about getting the right ones? I can understand a 1" block in the rear but they should be closer than 3".
  14. muddysub
    Jun 23, 2001
    10,452
    489
    [/ QUOTE ] i pretty much prefer the way it looks.
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I have run into some braking problems with the "saggy butt" only in a bit different situation. My wife had a tacoma at one point with a pop up camper and I did notice better braking after I put a set of overload leaves on it to help it sit more level when the camper was on loaded. I didn't analyze this too deep so at least part of it may have been the better handling due to the extra stiffness but I think it helped distribute the braking load a little better from front to rear. And visibility was improved too.
