Tuffy Console
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jonathan, Jan 2, 2002.
  1. Jonathan
    Jonathan 1/2 ton status
    Apr 14, 2001
    293
    Little Rock, Arkansas
    I got a tuffy console for christmas, and was wondering if I should use the mounting bracket that came with it or just bolt it to the floor.
    77 Blazer, 350, NP203, K&N, 31-inch Cooper Discoverers
    <a target="_blank" href=http://community.webshots.com/user/jonathandwill>http://community.webshots.com/user/jonathandwill</a>
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I'd use the bracket it helps to level the box and route your wires for the stereo if you got the deluxe stereo console...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. Jonathan
    Apr 14, 2001
    293
    Thanks. Also, when I set it in there to see how it fit I could barly reach the seat belt buckle, did you have his problem? Is their an easy solution?
  4. dyeager535
    26,980
    If the '77 console mounts anything like the "newer" ones (like my '86) DON'T use the bracket it comes with. Drill 4 extra holes in the bottom of the console, and you can bolt it directly to the stock holes in front, and the bracket in the rear.
    The "newer" consoles used a bracket about 1-2" tall to mount the console in the rear, which put my tuffy console perfectly flat when mounted, and the seat belt ends are easily reached.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
