tune up issues
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jun 24, 2001.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 and i replaced the wires with msd 8.5mm, i have the msd hei coil, the cap and rotor, i have ac delco rapidfire spark plugs but for some reason my truck is running very rough at idle and it seems like there is a lack of power, there is a backfire through my exhaust as well any help would be appreciated
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Sounds like you have a plug wire installed wrong. Check to make sure your wires are in order
  3. Chaotical
    Chaotical Registered Member
    May 10, 2001
    29
    SLC, UT
    From what I know about putting a different Ignition system on.. you have to have a Spark Plug with a higher resistant arch.. modified plugs won't run as well when your pushing alot of juice through them... a standard 99 cent plug will work better then a , split fire, quad split or rapid fires, or even platinum plugs... .....
    85 Jimmy 4" Lift, 3" body bought have not installed yet, Dana 44, 14bff,
    37" SSR's Yes they FIT with a 4" lift and don't rub.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Check your plug wires first, then if that doesn't get you anywhere, pull your plugs and see if you bashed an electrode closed while you were installing them.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
