tune up ?? on '90..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Jul 8, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    tune up ?? on \'90..
    What do you guys/gals recommend when doing a tune up? And how often do you do one or have one done? Dont want to take it to a shop unless its necessary.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Re: tune up ?? on \'90..
    I do plugs, cap/rotor, wires, HEI module, and coil. I'm a firm believer in doing everything at once, rather than waiting till something goes wrong. Since it's all taken apart anyway, may as well replace it all.
    I usually do it every two years, or if I'm having some sort of problems.
    <font color=red>Cripplefight!!</font color=red>
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A> Updated finally[​IMG]<P ID="edit"><FONT SIZE=-1>Edited by Pugsley on 07/08/01 00:11 AM (server time).</FONT></P>
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    fuel filter with every oil change
    Dave
    Beauty is in the eye of the beer holder.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Check out the O2 sensor while your in there.....
    Murphy's Laws on Life:
    "A bird in the hand is worth three Kleenex."
    <A target="_blank" HREF=http://www.K5.rockcrawler.com>http://www.K5.rockcrawler.com</A> *under construction*
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't forget air filter and checking your ignition timing (yes even on a fuel injected engine, I've cought them really slow before!).
    Tim
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Along with everything else make sure to service the trans.
    <font color=blue>Wayne<font color=blue>
  7. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    How do I know if the O2 sensor is good or bad? And where is it located? TIA
  8. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Should be driver's side exhaust pipe. O2 sensor is just about $15, I just replaced my original one. Not hard, just might be a PIA if you hit a lot of mud.
    "I am Republican. Not a baby-killing, tree hugging, land grabbing, touchy feely, hypocrite wuss democrat!"
  9. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    So there is no adjusting or anything like that I need to do besides the timing if need be? TIA!
