tuning edelbrock carb for emissions?HELP!!??
Discussion in 'The Garage' started by moturbopar, Jul 23, 2005.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    hi all I took my 79 blazer through emissons today, it did well except on HCs on the loaded reading. Here is how it did.
    idle HCs 110 max of 220
    , COs 1.55 max of 2.00
    loaded reading
    was 281 max of 220
    COs 1.35 max of 1.50
    I tried retarding the timing a little but it really messed with the idle readings.
    Anyways I was wondering if I should step down 2 jet sizes to reduce the HCs on loaded? The carb is a 1406 edelbrock performer. The jets sizes and needles are .97 jet with the .75x.47 rods.
    I was going to change rods but they dont make any that are leaner. I have a set of .92 or .95 jets. Which should I try? I only have one retest and dont want to spend another $19 on another test. do you guys hink jets will help the HCs ?
    Shawn
  2. puckhead
    puckhead 1/2 ton status
    Jun 17, 2005
    112
    colorado
    what is your altitude there?
    i can tell you what i put into mine for my altitude approx 5280'
    you may need plugs or wires high hc usually indicate a cylinder not fireing
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    try putting a cap full of acedtone in youre tank and a tune up if you haven't already.
  4. rumbly truck
    rumbly truck 1/2 ton status
    Jul 4, 2005
    132
    utah
    which powervalve spring are you running. i think a 1406 comes with the yellow one about 4" hg you might try a couple of jet sizes down and a stiffer spring to try to keep more fuel out of the primary circuit until you need it
