Tuning The 350 FAQs (basic tuning for dummies)
Discussion in 'The Garage' started by hi pinion, Mar 21, 2006.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Okay , my 74 needs tuning,
    The motors been re built, it sounds like it has a cam , (350), i can tell its been rebuilt too, just by the sound.....
    From Desert Rat himself....
    "The engine is in good condition, rebuilt 350 with mild cam, Edelbrock carb, Weiand intake, headers, MSD ignition. "
    Now,,,:D
    As far as the condition of the carb, i havent a clue,,,, it was on there when i bought it. EDELBROCK is all i know....
    DR says it has MSD ignition, i cant find a box like the mallory has anywhere, but its got NO coil wire i can see,,,,so what kind of ignition is it then? :confused:
    MY QUESTION IS
    What should i do with the thing? What are the steps to go through to make it run killer? Its sumbling a bit, and isnt running right.Should i rebuild the carb? Or try to clean it up and tune it up first? If so, how do i start from ground zero? Like , im a NEWB MAN!:haha: HELP!
    Go through the steps please..... its a mild motor, not to radical at all.Vac advance? WTF is vacum advance man? What is it, should i check it, or what?Is it like muff? :haha: :D
    I have a pair of channel locks, and a screwdriver
    GO!:haha:
  2. hi pinion
    Sep 25, 2003
    5,354
    HERES A PIC
    to "clear things up" for you :rolleyes: :haha:
  3. hi pinion
    Sep 25, 2003
    5,354
    Oh yeah, its got new plugs and new wires, new fuel pump.......
  4. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    the 14bolt axle is shaved for clearance. A great mod.
    The best mod for performance: Shave the Muff!
    My motor sounds almost identical to yours, but does a little worse that sputters. A boy is coming out tomorrow with a holley we are going to try out and see if its just carb issues :bow: Thank you Havoc Off Road :waytogo:
    thanks,
    James
  5. hi pinion
    Sep 25, 2003
    5,354
    Thats good for you! :haha:
    So you got nothing.........:haha:
  6. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    1. There is no way on the face of this earth that anyone can tell if an engine is a rebuild or original just by listening, because the two don't make a different sound.
    However, you do have a rebuilt engine since it does have a cam in it along with all the other performance stuff that is usually associated with a mild build. It doesn't hurt that the PO said it was rebuilt too.
    2. It sounded fine to me. Like I said the day we moved it, it did not sound like it needed much of anything. It revved up good with quick throttle response and had a good idle to it. I see no reason to do anything else to it. I would check the timing at idle, set it at or around 12*, it's probably already around that, and drive the thing. It's a little cold blooded but that is a carbed motor for you, that is just a characteristic of not having a computer monitoring the engine.
    Oh, and it probably has HEI, where everything is under the distributer cap. I would guess there is an MSD ignition coil in, I put a Pro Form in mine but I don't think they really do much over stock anyway. HEI is pretty powerfull stock.
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    do you have a timing light? You disconnect your distributor's vaccume advance, and plug that port at the carb. Clip the timing tab to #1 plug wire. See what she's timed at. I would start with timing, before you blame the carb.
    thanks,
    James
  8. hi pinion
    Sep 25, 2003
    5,354
    No no no, you can tell just by listening its not tired and weak, like its more fresh, than weak and tired.You can tell to a certain extent. It sounds "fresh".
  9. hi pinion
    Sep 25, 2003
    5,354
    When you drive it, its not the same, it needs tuning man, just to fine tune it in, i was with DR , and we drove it all around, you can tell its off a little!.
  10. hi pinion
    Sep 25, 2003
    5,354
    Does anyone have a LIST i can go by? 1234.......
    Like start again going over everything, timing etc?
    Also what should of projectile/ weapon should i use to smash my delbrock carb up with?:haha: Because some say its junk and its garbage, and just pour gas down the intake with a spray bottle and id be better off! :haha:
    I cant afoord MPFI right now though! :D
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    It is a lot like muff...
    suck, squeeze, bang, blow, all at the right times and she's purring like a kitten. :wink1:
  12. hi pinion
    Sep 25, 2003
    5,354
    Its another reason why i haven officially joined the NCOR at all man, everyone there ive seen is from here, and is already burnt out on my questions,,,,
    As i was in the lounge for 3 years figuring out a game plan.I finally found a truck, and got in a direction. :D
  13. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Try buying a metering rod kit for your edelbrock. Try the next size down of metering rod. Also you could adjust your accelorator pump. I've had to do that to all of my edelbrocks I've owned. Even my brand new one. Try putting it (your accelorator pump) on the lowest setting to get rid of stumbling and bogging down up acceleration. Also, see about getting a K&N air cleaner that would be a great upgrade for your motor (or any motor).
  14. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    That'll be $1 please.... :wink1:
    Jake....
    shoot me a pm tonight and I'll go over the tuneup basics with ya....
  15. hi pinion
    Sep 25, 2003
    5,354
    Cool thanks. Im gonna get the numbers off the carb today also, to see what model it is.:laugh:
  16. hi pinion
    Sep 25, 2003
    5,354
    Thanks, im gomma look into some off road floats if those are any good also.
  17. kgillyk5
    kgillyk5 1/2 ton status
    May 29, 2003
    1,830
    Fultonville, NY USA
    I agree with 78 Sub, start from the MUFF end and work backwards.:D
  18. hi pinion
    Sep 25, 2003
    5,354
    :D
    Whell, Cannmore is the one who left the gate open to lounge man, blame him that the zoo aminals got out:haha:
    The muff phase has passed, i guess you owe me one dont you! :haha: :D
    Jake
    Besides look at all the awesome tech it has in it so far:rolleyes: :rotfl:
  19. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Spend the bucks and take it to a shop with a diagnostic (Sun) machine and a tailpipe sniffer. That will pinpoint any deficiencies, such as weak ignition, low compression, or a carb out of whack.
    Every Edelbrock I have fooled with has a low speed stumble, no matter what model it was. I say put a good rebuilt QJet on it,if the existing carb has any serious issues.
  20. hi pinion
    Sep 25, 2003
    5,354
    Thanks. Thats what im hearing alot actually about the edelbrocks.:thinking:
    The history/condition of the carb is unkown really, im gonna look at it today....
    Jake
