"tuning up" a handheld?
Discussion in 'Communication (CB | GPS | HAM)' started by dubl_t, Mar 22, 2003.
  1. dubl_t
    dubl_t 1/2 ton status
    Jun 8, 2002
    141
    Oregon
    \"tuning up\" a handheld?
    I'm not vey "cb" literate, but I'm slowly learning. I believe a guy can use "export" mobile units to get more power, but can anything be done to handheld units?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Re: \"tuning up\" a handheld?
    In my opinion, a handheld CB is useless unless your standing on the interstate overpass and talking to a vechile you're looking at. Even then they might not be able to hear you !!! Well, that's just my opinion. But a pair of them would probley be okay for the kids to use as walkie-talkies.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    All the handheld CB's that I've seen take 8 or 10 AA batteries and use them up pretty quickly. Any modification to get one to kick out more power would just kill the batteries even faster, assuming that the batteries can even supply enough current to support the additional output to begin with. Long distance communications are just a dream for most handheld CB's though. Even if you can get it to transmit a strong signal, the small antenna and cheap/poor receiver section prevent you from hearing other people. /forums/images/graemlins/frown.gif
    I have one that I usually take on 4-wheeling trips. It's an awesome way for a spotter to communicate with a driver instead of relying on shouting and frantic hand signals. /forums/images/graemlins/thumb.gif
  4. dubl_t
    Jun 8, 2002
    141
    Oregon
    my thoughts were to use cb's instead of frs/gmrs when camping, since there's a cb in the truck. I'll probably go with the gmrs though, for extended range. Now, what about bumping those up?
  5. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Some GMRS/FRS handhelds can be tweaked a little for more output but not by much.
    If you want it for around the campsite etc I'd say GMRS or even the newer MURS radios. FRS is pretty much useless in the woods unless you are really close. MURS is limited a little more on the most legal power you can have compared to GMRS. Given equal power levels for both a GMRS and a MURS radio the MURS radio will reach a little farther in a wooded environment. MURS is limited to 2 watts and is free to use just like cb or frs. GMRS has higher allowable power outputs but costs for a yearly license.
    Also anything other than FRS can have a larger antenna than the stock little rubber duckie that comes with the handheld stock. You can add a better antenna to increased range.
    If you're interested I can dig up some links to some MURS radios.
    OR........ Get all your friends/family to become Amatuer operators and you don't have to be limited by power... you can use up to 1500 watts as a ham. /forums/images/graemlins/smirk.gif
  6. rebelk5frk
    Dec 29, 2001
    815
    Houston, TX
    There are also "export" handhelds too. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  7. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    [/ QUOTE ]for that matter, there are Linears... /forums/images/graemlins/ignore.gif
    as for FRS being totaly useless in the woods, our scouttroop uses them to keep in contact with eachother, and we've had good luck with them at ranges up to about a mile. the only problem with them is everyone and thier dog has an FRS, which clogs the airwaves a bit.
    -Rich
