Tunnel Ram?
Discussion in 'The Garage' started by Gmck2500mudder, Aug 18, 2006.
  1. Gmck2500mudder
    Gmck2500mudder Registered Member
    Jul 21, 2006
    31
    Canada
    Any of you guys run tunnel rams on your rigs? Would they work well for offroading? I could make the space under the hood but I dont know if they are any good for offroadin.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Tunnel rams are good for high RPM/HP. Not the ideal for offroading unless you're doing mud drags or the sort.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    ^^^ What he said
  4. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Why does everyone think tunnel rams are bad for low end???? Mopar Muscle and Car Craft both have run tests that show the T ram making more torque across the board than any other intake. The runners are no longer than a TPI intake. It mostly boils down to carb selection.
  6. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    that'd be news to me.. and I would highly doubt it, articles or not.. it's been fact forever..
    straight from Weiand....
    They're designed primarily for drag racing, truck/tractor pulls, and performance marine applications where high rpm is required but bottom-end torque isn't. With their patented D-shaped port runners and large plenum chamber, they provide optimum thrust of the air/fuel mixture to the intake ports. They mount either single or dual square-mount carbs and, depending on the application, have power bands that run from 2,500 rpm to as high as 9,000 rpm.
  7. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Ask yourself where the torque starts. Sure, the tunnel can develop loads of tq. but not till around 3 grand & up.
  8. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    word up... get a good dual plane manifold and call her good.
  9. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Some of the manufacturers make " street " rams that make power in a more usable rpm range. Never seen a side by side test though....
  10. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    Had one on a 468bb chevy in a 72 blazer. Down low it was still a big block but after 3grand it was fuuunnnnn!!! It was always fun too open the hood,but not worth all the extra work of having them.:D
  11. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    If you look at the weiand tunnel ram in the summit catalog it says and I quote: "NOTE: Due to lack of low-rpm torque, not recommended for everyday street use." It's advertised power range is 2,500 to 10,000 rpm.
  12. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Don't you hate how it makes you enter at least three characters to post?
  13. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Keeping everything sycrnized for offroading is also a PITA
