Turbo 350 Shifting Problems?
Discussion in 'The Garage' started by OffRoader93, Jan 4, 2004.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    My transmission will only shift if I manually shift it. The fluid is at the right level. Was wondering if anyone has had this problem. Thanks for any information.
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Did you check the vacuum modulator line and make sure your getting vacuum?
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Like Ryan said, check the modulator valve hose, if it is connected and still doesn't shift then the modulator is probably bad. The tranny will however still shift but usually not until the RPM's are about 4500 or so.
