Turbo 350 Transformation
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CooknwithGas, May 29, 2002.
  1. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Can anyone tell me if a standard turbo 350 Transmission can be modified to fit my 1975 blazer with an NP203? I'm assuming all TH350's are alike and I can just change the back-end with parts from my old transmission. Is this true?
    Thanks for any help.
    Scott.
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    my th350 is connected to a NP203.....should be a way
    NITRO
  3. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    I did mine. I have not run it yet. You will need to get a rear shaft from a 4x4 transmision and swap it out.
    Luke
  4. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    I didn't word my question properly. I already have a TH350 in the truck. I want to take a NON-4x4 Turbo 350 that is in better shape and install it in my truck in place of the original TH350. Question is - Can any Turbo 350 be converted to a 4X4 version with some parts from my old TH350?
    Thanks for your help.
  5. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    yup
    NITRO
  6. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Yes BUT If you have a 2wd version it will have a long shaft. You will need to install the short shaft. PROBLEM= must disassemble the tranny to do it. Might as well rebuild the old one. Should be done for around $400. if you take it to a tranny shop.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Cut the tailshaft with a sawzall and clean it up with a file. Hillbilly, but cheaper than having someone rip apart a 2wd tranny, getting "stuck" with a 2wd tranny case and 4wd tailshaft.
    If you're gonna spend money on a TH 350, make it a 4x4 model, with the thicker, "K" case. Otherwise, just cut the shaft down.
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    th 350 has 4 output shafts. and only one for a 4x4. all th350 will bolt to all t-cases off a th350. in 75 a th350 and 203 was the most common blazer out there. are you converting from manual?
    grant
  9. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    th 350 has 4 output shafts. and only one for a 4x4. all th350 will bolt to all t-cases off a th350. in 75 a th350 and 203 was the most common blazer out there. are you converting from manual? and if you have a 2x4 trans all you need is the output from a 4x4
    grant
