turbo 400 into NP205, need adapter!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bullets72, Oct 17, 2003.
  1. bullets72
    bullets72 Registered Member
    Oct 17, 2003
    15
    I have a 72 K5. I'm taking the Th400 out of my rolled 85 K20 truck that was mounted to a NP208 and adapting it to the OEM 205 off the blazer that was mounted to a TH350. I have been told that the adapter housing was a factory GM part to adapt the two cases but it is hard to find. I have also been told that there is no factory part, and I would have to spend the $485 for the conversion Kit from Advance Adapters. Does anyone have this part or know where I could get one? What other 205 mods are reccomended? /forums/images/graemlins/k5.gif
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Dont use A/A they are a waste of good money.
    Call up Ord they can fix you up.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Might want to ask this question in one of the 4x4 related forums and it might get better response /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif
  4. kennyw
    Jun 9, 2002
    13,223
    94
    You are going to need to change the 205 from 27 spline (TH-350) input to a 32 spline (TH-400) input. Contact ORD for the kit to do that.
    Next the adapters are probably not in production anymore by GM and you will need to search for a used TH400-205 adapter.
    Another problem may be the out put shaft length on the tranny itself. I believe there are several versions depending on the tcase used for the TH400 and dont think the NP208 and NP205 versions are the same. UglychevyZZ4 has a TH400 in the for sale forum that came with the NP205 (but he already sold the adapter and 205).
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Check ebay, some times there on there.Also check boycee equipment they sell them. Around 180.00
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    EXACTLY WHAT KENNY SAID
    AND YEA the out put shaft is usually different on the stock LENGTH 400-208 then on the 400-205
