TURBO 400 OR 700r-4, I think I may go with a 400
Discussion in 'The Garage' started by MEGALADON, Oct 10, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    After hearing how most here are having problem with 700's, I think
    I want to put the 400 that came with my 454 out a 1 ton truck. I had to buy a shaft for my 700R-4 in order for it to fit up, do I have to buy a shaft for the 400 to????? I know the tail shaft cover has to come off.
    If I did this would the transfer case have to be moved?? I know the 700 would
    fit without any mods to the transfer case, because it came with a overdrive when new.
    Its on my 82 GMC truck, I have a 350 trans in it now, but the case is cracked.
    It still runs and drives with the BB, but I know i'm gonna bust it soon.
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    go 400 with a BBC.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get a TH400. I have a 700 in my truck and I have a 400 in my garage waiting for the 700R4 to die. With a BBC I wouldn't even consider a 700R4 because you would have to spend all kinds of money on the tranny to get it to live for a long time behind a BBC.
    Harley
  4. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    350 and 700 = 27 spline shafts
    400 = 32 spline shaft
    adaptor to tcase is 4 bolt for 350 700 tranny
    400 is 6 bolts.
    bbc best to go 400 tranny. and as it had 454 factory it should have the better clutch packs in it than a light duty use 400. by this i mean higher quanity of clutches per pack.
  5. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
  6. sweetk30
    Nov 1, 2004
    25,540
    539
  7. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    THANKS sweetk30, My next question would be does the t-case have to be moved, or all I need it the adapter on e-bay :thumb:
  8. sweetk30
    Nov 1, 2004
    25,540
    539
    also need the 32 spline input. this will require spliting the tcase . good time to freshen it up. and also need the tail shaft for the tranny.
