Turbo 400 output shaft lengths
Discussion in 'OffRoad Design' started by thebigdaddyof2, Apr 25, 2005.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    From the info on your site, I understand there are 3 different lengths of output shafts for the Turbo 400- depending on the version of t-case used.
    But what about the later, round pattern 205?
    Do the later T400s have the same 4.5" shaft stickout like the older T400s?
    thanks
  2. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    No, it's shorter - I think it may be the same as a 208 application. I have one at home and can post a measurement tonight if needed.
  3. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Nvrenuf,
    Any idea on the length of the shaft stickout?
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Dude I'm sorry I forgot about this! :doah:
    The tailshaft "stickout" for an '85+ TH400 with a round pattern 205 = 2.25".
    :thumb:
  5. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Hey, no problem.
    Thanks for the info!
    If you measure ~2.25", I am wondering if this is not the same as the 208 version- which is stated by SW to be ~2.5".
    If so, I suppose GM had only one T400 output shaft length to deal with (by the mid 80s) and thus created the long input 205.
    Can anyone verify this?
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    In the tranny output shaft world, 2.25 and 2.5 are the same thing, we run into 1/8" variations all over the place.
    I'm guessing that the standardization thing is the reason for the long input gear change. It does make it easy, you use one TH400 for everything, 3/4T and 1T. We've run into some military trucks with long inputs in fig 8 cases, I'm guessing for the same reason.
  7. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Information from the man who's probably seen it all!
    Thanks, Stephen.
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Funny thing is, despite all the exposure to different stuff, I still get surprised.
  9. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    I'm going dredge this one up from the bottom.
    I have the 2.25 inch output shaft. Trying bolt this up to my 241 doubler, I need the next size longer output, any one know what that is and where I can get it?
  10. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    We can get you any of the TH400 output shafts.
    Are you sure you need the longest one? I would think you need the one you have which matches a 208 or 241 adapter.
