Turbo 400 problems
Discussion in 'The Garage' started by bassin4507, Oct 23, 2004.
  1. bassin4507
    bassin4507 Registered Member
    Dec 22, 2003
    23
    Westport, MA
    My turbo 400 won't downshift, when I floor it. The only way I can get it to downshift is to manually do it. I know there is a vacuum line going from the carb. to the transmission, is this what makes it downshift? Or is there supposed to be a cable ?
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The downshift signal on a Turbo 400 is electrical. There should be a switch on the gas pedal bracket that turns on when you floor it. That sends 12 volts to the connector on the drivers side of the tranny and engages kickdown mode.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    where is it at on the gas pedal bracket? Mine downshifts sometimes and sometimes it dont, Im thinkin maybe the switch mount has come loose, or broken, so it only engages sometimes.
  4. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    inside truck should be the only switch on the gas pedal.
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I mean is it at the top of the arm or down nearer where it bolts to the firewall, cause I hadnt seen a switch down there that I remember
  6. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    it's closer to the top. above where it mounts to firewall with the three bolts. a chiltons manual will have the correct adjustment procedure. it's easy! my truck was an original 4 speed so i didn't have the switch parts so i used a lokar performance kickdown cable kit. it mounts to carb linkage via a cable. not as good as a factory setup but it works.
