turbo 400 ?
Discussion in 'The Garage' started by 77scottsdale, Jan 21, 2007.
  1. 77scottsdale
    77scottsdale Registered Member
    Dec 17, 2006
    93
    georgia
    i have a short tailshaft th400 looks like this one but its stock not b&m[​IMG]
    will a np205 and adapter plate work with it i think it is 4.00in shaft 32 spline came out of an 85 2wd lwb
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    pretty sure the tailshaft is too long once the tailhousing is removed.
  3. 77scottsdale
    Dec 17, 2006
    93
    georgia
    i know it aint the right way to do things but can i cut some of the shaft off
  4. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I've heard of some guys doing that with some combinations. Not sure if it was a 400. watch the spline engagement length. It could well be that after you cut it short enough, there won't be enough left. Can't remember how long the splines are on that trans.
  5. goldwing2000
    goldwing2000 Guest
    Also be careful of how you cut it. If you get it too hot you'll lose the heat-treating and it'll break under load.
  6. 77scottsdale
    Dec 17, 2006
    93
    georgia
    here is the specs of the one i have 4.5" shaft with 2.75" of that being spline
  7. 77scottsdale
    Dec 17, 2006
    93
    georgia
    if it can be cut i will use a band saw with lots of oil or some water, does any one have the specs for a 4wd th400
  8. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    If your tranny is exactlly like the one you pictured, AND your transfer case is the short 32 spline input figure eight style with the tall adapter, it will work.
    Jimbo
  9. 77scottsdale
    Dec 17, 2006
    93
    georgia
    do u have a picture of a figure eight style and a tall adapter
  10. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 2wd fixed-yoke TH400 uses the same output shaft as the 80-84 TH400/NP205.
    The 85+ TH400/np205 (round pattern) version uses a shorter shaft.
  11. 77scottsdale
    Dec 17, 2006
    93
    georgia
    what about a 208 and a th400 adapter
  12. 77scottsdale
    Dec 17, 2006
    93
    georgia
    its not a fixed yoke it has a bushing and all that the yoke slides into on the tail shaft housing
  13. 77scottsdale
    Dec 17, 2006
    93
    georgia
  14. goldwing2000
    goldwing2000 Guest
    Do you have the t-case yet? If not, what about going divorced?
  15. 77scottsdale
    Dec 17, 2006
    93
    georgia
    yea i thought about that too, are divorced dodge cases easy to find
  16. goldwing2000
    goldwing2000 Guest
    Availability comes and goes. Sometimes I see a lot of them, sometimes none for months. It's a good route to go if you have the room for it, though.
    It generally requires custom-length driveshafts but the payoff in cheaper trannys and better driveline angles is worth it, IMO. Besides, if you get a good HAD or Tom Woods shaft, you're good pretty much forever. Maybe just need to buy u-joints occasionally, same as with any other truck.
  17. sweetk30
    Nov 1, 2004
    25,528
    527
    horseheads , ny 14845
    look for a international truck or suburban style body one. thay have all divorced cases and thay are 205. but the best factor is thay are 34" frames. gm is 34" frames. so grab all the mounting brackets and bolt it in basicly.
  18. goldwing2000
    goldwing2000 Guest
  19. goldwing2000
    goldwing2000 Guest
