Turbo any one.
Discussion in 'The Garage' started by ross'blazer, Feb 12, 2005.
  1. ross'blazer
    ross'blazer Newbie
    Feb 5, 2005
    Layton, Utah
    does any body know where i could get a turbo for my 1991 blazer.
  2. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
  3. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
  4. wallew
    wallew Guest
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    How can we help you find a turbo when we dont even know what motor you have:confused:
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    damn I'm watching that Air Research turbo ;) Its meant for a carbed application so it isn't any good for him.
  7. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I didnt even think about the turbo being for fuel injection.:screwy:
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    To run a turbo on a 91 TBI blazer would require a lot of Chip work and some time on a dyno. Map sensor does not like the high boost that turbos can give and may not work at all.. Prolly take a real wiz at chip building to make one work with TBI. it would be a lot cheaper to convert to a carb if you want to go with a turbo.
    I think you would be better off going with a Supercharger. Whipple, Vortec, and Holley make bolt on superchargers for TBI trucks.
  9. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    try Wayne at GearTechHD.com
    Geartech can fix you right up.
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    this is the new twin turbo kit from banks for a SBC:
    [​IMG]Pretty damn sick if you ask me, not what i would want in my truck i dont think, but if i was building a street rod, hell ya sign me up:D
  11. wallew
    wallew Guest
    S,
    I AM building a street rod out of my 91 GMC SUB and that is the setup I'm shooting for.
    The turn key from Banks is $38K, which I don't have.
    However, I can have mine rebuilt properly (7.5:1 compression) for $4k, the twin turbo is $6k and then just add TPI ($4k from Banks - hoping to find it cheaper some place else) and I'm set on engine mods. TOTAL if I have to use Banks TPI is about $14k. Less than half of the built Banks motor.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    get a factory TPI and mod it to work.
  13. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    two turbos on an sbc? better have a damn good bottom end.
    superchargers and turbos are definetly badass but wear the motor out ALOT quicker than I would want. If i had the $$$ I would try to get as much hp as I could out of it before I spent that much on a twin turbo setup.... You can build an aluminum block 400 that will crank out 600 hp naturally aspirated and do it for the same cost of the banks twin turbo setup-around 11 grand. I plan to put something like that in a camaro in the future; oh man an aluminum block 400 that cranks out 600 hp naturally aspirated in a tricked out camaro with an all wheel drive kit...... I think I just...........Yup..... I just had an idea.:haha: :saweet:
    Or you could go with the iron block 400 and spend the extra 2 grand on a supercharger. that thing would show up stock cars.
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    /me yawns
    you could build a blown or turbo motor that would last just as long as a naturally aspirated if you built to fit not just slapped one on a stock motor. Even then, low boost and you'd be good. People run those bolt on supercharger kits with LOTS of miles on them with no issue.
  15. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I still doubt they would outlast or last as long as a naturally aspirated motor.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    amazing all the ricers with 150+ miles on the original turbo motor
  17. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Im just saying if you can build a motor that doesn't have to deal with excess pressure and turbo lag then why not... that extra $$$ can be put into high end internals and fuel delivery system without stressing the motor as much as any kind of boost will. Its a known fact that a turb/supercharged motor won't last as long as a naturally aspirated motor. I've seen 350's that had over 300,000 miles on em and still had enough guts to light em up bone stock. 150+ is good but if you consider that to the life of an equally powered NA motor its not much.
