Turbo experts: need your thoughts
Discussion in 'The Garage' started by muddybuddy, Jan 1, 2007.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    if the compressor wheel has touched the houseing, the turbo is spent and need an overhaul. if you look close, I think it has.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    turbos run tight tolerances. They wouldn't build boost if they didn't. I don't see what you are saying with the "looks like its contacted". Just looks like the way the picture is and the angle it was taken its close to the housing, as it always is.
    you would almost certainly have to make a new downpipe. get a larger crossover if you do get it. The stock one is piddly in size.
    http://www.ssdieselsupply.com/product_97_6.5TD_Crossover_Pipe.html
    http://www.ssdieselsupply.com/product_173_Stainless_Steel_6.5TD_Crossover_pipe.html
    not that the aftermarket ones are huge in comparison. But any increase in size is welcomed.
  4. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I don't see anything obviously missing except for the intake side of things. There should be an intake piece that bolts to the manifold, and if factory 6.5, there should be a cover piece that says "turbo 6.5 power" or similar. Much of it should be hard line, with rubber adaptor hoses and clamps.
    Rene
  5. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    I've overhauled turbos before, I know what they need. do you see the shinney strip right at the blade tip. thats where they touch when the bushings are toast.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah now I think I see what you mean. Could be right.
