turbo!?
Discussion in '1982-Present GM Diesel' started by KGsK5, Jan 13, 2007.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    so i got out to the junkyard today and was lookin around and saw a newer chevy 2500... didnt think much of it cuz i was busy with some other stuff... but i eventually got around to popin the hood and... its a 6.5 TD. i didnt even think to look and see if it was a deisel. so anyway... i may be getting a turbo to put on my 6.2 for cheap... how hard is it to throw a 6.5 turbo on a 6.2? is there anything that i should look at before i grab it?
    thanks
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Do you have AC on your '83? As long as you don't have AC it will fit in without much hassle.
  3. KGsK5
    Aug 26, 2006
    343
    i do... but i think i can make it go away in favor of a turbo...
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    There is a plate on the intake side of the turbo. Look at it to see if it is a GM-3 or GM-4 all the way up to a GM-8. 8 is the best but it has a vacuum regulated wastegate and you need a mechanical which was dropped after the GM-3. Most guys fab thier own.
    You'll need the exhaust manifold for the turbo. The other side, driver's, is the same. There is a crossover pipe as well but the stock one is crappy and you can buy a better aftermarket for about $70
    Take at least the upper part of the intake manifold (top).
    Open up the air filter box, if it is a round filter take the box & hose, etc. If it is a flat rectangle it's not worth getting. They have a bad reputation for leaking:eek1:
    You really need to get a Boost and a EGT gage as well. You can trash your engine pretty fast without them.
    That's about all I can think of.
    Oh, if you have AC you'll have to loose it from the firewall. Some have swapped out to a S-10 and had good results.
    Good luck!
  5. KGsK5
    Aug 26, 2006
    343
    awesome. thanks. now i just have to hope that it is still there on monday...
    ill be sure to post up with pics when i finally get this project moving.
