turbo
Discussion in '1982-Present GM Diesel' started by 82K5_6.5L, Jan 31, 2003.
  1. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    hey i have a 6.5L and am lookin for a turbo, does anybody know how much a new one would cost? and how would i install it??
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    You would need to get a complete system, most likely one from Banks. A new Banks setup runs around $1800. They're the only company still making a turbo setups for our trucks. You would need to get the 6.2L Sidewinder setup. You can sometimes find complete systems on Ebay, which usually sell for $500 to $700.
    A turbo system includes the turbocharger, a passenger side exhaust manifold to bolt the turbo to, a cross-over pipe to connect the two manifolds together, an air cleaner assembly, a pressure chamber which bolts to the intake manifold, an exhaust downpipe, usually a complete exhaust system, oil feed and return lines, and typically includes an EGT guage to monitor exhaust temps.
    You could also get a factory GM 6.5L turbo setup, but this is harder to do. You would have to get all the parts from a dealer or scrap yard, or an individual who has done that already and wants to sell his system. Also, this system won't bolt in to the older body-style trucks, because the turbo will hit the a/c evaporator housing. If you don't have a/c, then this isn't a problem. Otherwise, you'll have to figure something out.
    I have a turbo setup that I'm going to be installing on my '81 this summer. I bought a turbocharger from an individual, an exhaust manifold from Banks, had an adapter made to bolt the turbo to the manifold, had a downpipe made for the exhaust....I still need to make a cross-over pipe, and get some sort of air cleaner assembly. I have a 4" muffler from KD that will round out the exhaust system. When I'm done, it will go from 3", to 3.5", to 4", and probably finish up with a 5" tip. I'll have around $500 invested in it when I'm done.
    Casey
  3. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    arveetek /forums/images/graemlins/smile.gif he already HAS a 6.5L I think your post made it sound like he was looking for a 6.2L turber.
    Actually I think getting a turbo for a 6.5L is easy. Check Junk Yards etc. they should have plenty of parts you can pick off.
  4. arveetek
    Mar 1, 2002
    722
    Yes, but it's mounted in an old body style truck....which means a 6.5L turbo won't fit without major modifications. The only differences between a 6.2L and a 6.5L are internal...so it doesn't matter if he has a 6.2L or 6.5L, it's the style of truck it's in that makes a difference. I suggested a Banks Sidewinder for a 6.2L because of ease of installation and fit. There are several 6.5L trucks that I know of using a Banks Sidewinder with good results.
    If he had an '88 or newer body style truck, then the 6.5L would probably be the way to go.
    Casey
  5. arveetek
    Mar 1, 2002
    722
    82,
    Here's a pic of my turbo mounted on the Banks manifold on my spare 6.2L. This will give you an idea of what a turbo looks like on our diesels. This is just the turbocharger, no intake or exhaust pipes or oil feed lines attached yet.
    Here are a couple more pics:
    pic 1
    pic 2
    Casey
