Turbocharger + Carburation = Boom?
Discussion in 'The Garage' started by BigBurban350, Oct 7, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Will a turbocharger ignite the A/F mixture as it passes through it?
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    No /forums/images/graemlins/grin.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are also "blow though" designs that have the turbo before the carb. Some use a special carb that is designed to deal with the pressure the turbo creates. Others use a housing around the carb so that the inside and outside of the carb are pressurized equally, resulting in no leaks due to pressure differentials. /forums/images/graemlins/cool.gif
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    Turbochargers and superchargers go back a lot further than EFI. Carbs have been used with forced induction many, many times before. You have to have heat or spark to ignite. The pressures in the intake and carb are still very small compared to those in the combustion chamber where knocking (detonation) occurs.
  5. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
  6. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Geez, I hope not. I've got a draw-thru turbocharger on my old BMW motorcyle. 'Hate for it to go boom so close to the "boys" /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif
