turn signal / brake light problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by funkycold, Mar 11, 2004.
  1. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    I tried to search for this before posting, but was not able to find anything.
    Whenever i use my turn signals they work fine right up until i step on the brake pedal. once i step on the brake the brake lights take over and the turn signals stop working. When i taek my foot off of the brake pedal, the turn siganls work again. I have changed all the bulbs, with no luck. I checked the switch and there is power coming out of it since the signals work when i am not on the brake. I did not find a broken wire of anything else. Is there a module that is connected to the turn signal and brake light that may be bad or something else?
    Any suggestions would be great. /forums/images/graemlins/confused.gif
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The switch in the steering column is probably bad.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The turn signal and brake circuit run through the turn signal switch.
    That would be next spot to look into.
