turn signal, but no parking light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 8, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I noticed today that the parking light on the drivers side did not come on when the lights were on. The driver side turn signal works, so what could be wrong? Thanks.
    Brian
    84k5, 4"Skyjacker lift,33x12.5 Goodyear MTR, 15x10 Bajas
  2. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Is it just on the drivers side?.. it could be a fuse, you know... check them. It could be a wiring problem too.. my friend's left brake light sometimes doesn't work.. if he puts the lights or the blinker on, it works, but the brake light kicks in once and a while.
    http://billybob.coloradok5.com
    It's all fun 'n games, till someone gets stuck.
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    yeah, the one on the passenger side works. uh, I am a bit retarded, where could I find this fuse?
    Brian
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Fuse block, it's under the dash.
    YEEEEE HAWWWWW[​IMG]
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    ok, didn't know if it was one those inline fuse kinda things. I'll go out and check in the morning.
    Brian
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If my memories serves me right your bulb might be bad. Have someone check if your brake light works on that side? The turn signal and the brake uses the same part of the bulb. The parking light is the other part of the bulb.
    C'moe
    <font color=black>the blazer is "Back in Black"
  7. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Thanks, I'll check that too.
    Brian
  8. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    The bulb has two functions and two wire's inside them. If you have turn-signal but not park, I would suggest the bulb is half gone..
    <font color=blue>Espen88k5 at:http://www.espen.coloradok5.com</font color=blue>
  9. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    2 bulbs...who would have thought?
    Brian
  10. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    There is indeed two filiments in the bulb, an 1157. The brighter filiment is for the turn signal and the other for the parking lights.. And remember to look close at the bulb, it is keyed to go in one way but it can be forced in which will blow one of the filiments out if left alone.
  11. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    Definitely the bulb, should take about 12 seconds to fix :^)
    Rene 81 Jimmy,350,SM465/NP205,FF14 bolt,HD Dana 44,3.73's,4"susp.,35"Grabber MT's,body in progress
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    It was the bulb. I went ahead and replaced both while I had the grill out.
    Brian
