Turn signal housing loose, Steering wheel wiggles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Jan 11, 2004.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I'm trying to get the old Liberator up and running again. The one thing that is stopping me from taking it on test drive is the tilt steering wheel being loose. It looks like the turn signal housing is loose (where it pivots for the tilt). The rest of the column is mounted solidly in the truck. Is there a nut that needs to be tightened? What would cause this? I've done several searches and looked through Chilton's to no avail. It's for a 1981 K5 with tilt steering. Local shop says they'll rebuild the column but I think something is just loose! Any help is greatly appreciated.
  2. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    There are bearings inside the column and when they get loose it does this.
    They can't really be tightened up with a nut or anything, they basically just need to be replaced or rebuilt.
    I took mine apart and bought the bearings from the dealer reassembled it and the woble was gone!
  3. Liberator
    Jul 16, 2001
    276
    Thanks for the reply! Was it a fairly easy task? What am I getting myself into?
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    90% of the time the only problem is that the 4 too-small-and-have-no-loctite-from-the-factory screws in the column work loose. /forums/images/graemlins/angryfire.gif They hold the upper section of the column to the lower section. Somewhere on the site is a great writeup on how to get to the screws to tighten them. I took mine out and applied loctite to the threads so that hopefully I'll never have to go in for that problem again. /forums/images/graemlins/thumb.gif
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The search function is hosed right now so ya can't even look for the article. /forums/images/graemlins/frown.gif Perhaps see if it is listed as a tech link from the main page?
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
  7. Liberator
    Jul 16, 2001
    276
    Wow! Great job searching! It looks like an excellent write-up. Three pages to print and very detailed in it's descriptions. Thank You!
  8. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I used the same write up to tighten mine.. I didn't replace any bearings.. I just tore it down.. and tightened everything I could find.. it really wasn't that difficult.. hope it works out for you.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    just tighten up the tilt screw, this is a VERY common problme with all GM columns that tilt
    ppl who say it needs rebuild are just wanting to get money from you by charging you a bunch for a simple fix
