Turn signal issues
Discussion in '1992-Present Chevy & GMC models' started by thezentree, Dec 26, 2006.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    My turn signals started acting up this morning on my 97 Yukon, and I can't figure out why. The left TS works as normal, but the right TS indicator in the dash acts like it shotgunned a case of redbull and then did a speedball, and the lamps themselves aren't working. The TS module under the dash is for both sides, and since the left side works fine, I assume that the module (what's the correct term?) is fine. The contacts are clean. I haven't had a chance to look at it, but, I'm assuming it's a wiring issue. Any advice as to where to start looking?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    usually when the bulb on the dash is flashing fast, it has a bulb out, either front or rear, just check the bulbs.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I had a short in my trailer harness that gave me fits.
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    x2 on the bulbs.
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    worst case that we change lots of up hear in the area i live. it might be a turnsignal switch . and fyi if you do need one just go dealer better parts. and you need a inverted tourqs socket to remove 2 bolts. i think its a little #3 bit.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I had this problem recently on a 00 Chevy van. Problem ended up being high resistance in the one turn signal socket. Bad wiring problem between the ground and ground wire. So anyway, it could be more than just a bulb. Check the bulbs first, then start checking the wiring all over, especially grounds.
  7. thezentree
    Sep 19, 2003
    7,198
    NC
    Thanks for the help yall, I suck at all things electrical.
  8. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    So, did you fix it? Did you check the torsion bar crossmember? Could be the pass rocker is misaligned?:haha: :haha:
  9. thezentree
    Sep 19, 2003
    7,198
    NC
    Shaddap. :rotfl:
    I took it apart and found that something short circuited and melted the circuit board in the taillight housing. Fun.
