Turn signal question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by drchan, May 12, 2003.
  1. drchan
    drchan Registered Member
    Sep 4, 2002
    74
    edmond, oklahoma
    I'm not sure what you call it but i wondering if any of you 1st Gen guys have the signal switch that turns off after you complete the turn. I have the one were you have to manually turn it off after you turn. Am i making any sense. I don't have tilt if that matters. do they make a switch that will fit my application. what exactly is it called. its not a big deal but sense my K5 is not my daily driver i'm always driving 2-3 miles with my signal light on(cause i forget to turn it off) gets kinda annoying.
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    That is the signal cancel. You can get them new from LMC, Chevy duty, etc. for around $10.
  3. drchan
    Sep 4, 2002
    74
    edmond, oklahoma
    ohhh, that's what you call it! shouldn't be to hard to hook up should it?
  4. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Yeah - how do you fix this? /forums/images/graemlins/confused.gif
  5. Blazerholic
    Blazerholic Registered Member
    Jan 12, 2003
    77
    Latonia,KY
    I beleive that it's also referred to as the turn signal cam. I'm also pretty sure you have to pull the steering wheel to install the new one. Shouldn't be too hard, but then again, there's that old adage that says "the cheaper the part cost, the bigger the pain in the *ss it is to install " . /forums/images/graemlins/eek.gif
  6. BLAZEN70
    BLAZEN70 Registered Member
    Mar 15, 2002
    43
    Southern California
    Just replace the cam. Its pretty easy to do. I replaced mine and it took less than an hour.
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Not a cam. There are two little springs in the column that cancel the blinkers. They are very inexpensive, and easy to replace.
  8. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    YEP...easy as long as you know what they are supposed to look like when they're installed!!! I bought the springs from ChevyDuty and then sat there like a dumba$$ wondering where they went....my column had NO springs in it so there was nothing to compare against. I finally gave up and bought a replacement column (used) since mine had other problems anyway.....
    I think I have pics of how the springs are supposed to look/fit if you decide to try putting them in.....
  9. 72yellow
    72yellow Registered Member
    Feb 24, 2003
    13
    Connecticut
    I have the same problem, I don't bother using them. Haven't found too many people that disagree on where I want to go. /forums/images/graemlins/laugh.gif
  10. brandoneh
    brandoneh 1/2 ton status
    Aug 1, 2002
    179
    Lake Stevens, WA
    My turn signal turns off when i take rights but not lefts....kind of weird!
  11. Blazer1970
    1,600
    Old Mission, MI
    Yup, one spring is broken. That's how mine was when I got it.
  12. drchan
    Sep 4, 2002
    74
    edmond, oklahoma
    for a while(recently) when i would signal left or right both lights on the bezel would blink like the hazards were on, but when i step out of the k5 just one blinker would be going left or right depending on which way i signaled. i think most of my problems stem from this GT steering wheel that is grinding really bad every time i turn. it was on there when i got the blazer. it's on it's way out as soon as i get another wheel.
