Turn signal stalk
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Feb 13, 2003.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    How do I get the turn signal stalk out of the windshield wiper switch located in the steering column. I've got the switch with stalk hanging out of steering column now, but don't see how to remove stalk for replacement in my 89 GMC Jimmy w/ int.wipers and cruise.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    push in and turn to the left
  3. dyeager535
    26,979
    You've gotta fish the wires through the column if I read you right.
    Or, find one of the later S-10's with similar column that uses a connector right there. You can cut and solder the new connector in and not ever have to worry about it again.
    Of course, if wiring itself is the problem, you'll have to fish it through the column anyway.
