Turn signals work with lights off......won't work with lights on
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Jan 21, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Turn signals work with lights off......won\'t work with lights on
    My turn signals work fine normally. Then when you turn on the lights and the left arrow lights up kind of dim, and neither one of the turn signals will work. Please help! Thanks!
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Re: Turn signals work with lights off......won\'t work with lights on
    Sounds like the parking light circuit is somhow shorted to the signal circuit. Make sure the bulbs are in corrctly and the sockets are nice and clean. Check the side marker ligths also.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  3. Michael
    1,576
    Sherman, Texas
    Sounds like the parking light circuit is somhow shorted to the signal circuit. Make sure the bulbs are in corrctly and the sockets are nice and clean. Check the side marker lights also.
    Michael[​IMG]
  4. Grim-Reaper
    7,385
    Atlanta
    Check your body grounds. In particulare the ground strap off the passenger side head to the firewall. Why it works with the lights off is it is pulling ground through the lights on the core suport. Once the lights are turned on the route is gone so it quits.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Make sure that your tail light and grille light park/turn bulbs are dual filaments. I've seen a single filament bulb mistakenly put in and it does the same thing.
    Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
  6. dyeager535
    26,982
    191
    you happen to have the wrong (or faulty) bulbs in the parking/marker lights front or rear?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
