turn signals
Discussion in 'The Garage' started by 86chevybanshee, Nov 12, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    what would cause mt turn signals to not work. the flasher is new and i checked all the fuses /forums/images/graemlins/confused.gif, its an 86 cab btw
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Bad ground? /forums/images/graemlins/dunno.gif
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    where would the ground come from. i put a front clip from a 90 blazer on it, the parking lights work, the hazzards work /forums/images/graemlins/confused.gif is it maybe the switch on the column?
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Try following the harness. There should be a ground somewhere along the line. It's been a little while since I messed with wiring some I dont remember off hand... It may possibly be a switch, but I would follow the harness first and look for grounds or possibly a bare wire..
