turn the key and get some knocking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Mar 24, 2002.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    rigth when the engine turns over it starts a knocking for about 2 seconds. what could it be??????
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    THAT WOULD BE WHAT CHEVY DO. CRANK IT AND IT KNOCKS ABOUT 3 TIMES AND GOES AWAY. MY 94 SUB. DOES THAT I EVEN PUT A CRANK ,BRGS. AND HIGH VOLUME OIL PUMP IN IT. STILL IT KNOCKS ON COLD START UP. I ALSO HAVE BEEN TOLD THE CPU COULD BE PROGRAMED TO ADD A LONGER CRANK TIME TO BUILD OIL PRESSURE. THE STRANGE THING IS, MY K5 HAS THE SAME MOTOR AND DOES NOT DO THAT. GO FIGURE
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It could be a Fram oil filter under the hood./forums/images/icons/wink.gif It could also mean that your oil is old and dirty and needs to be changed out.....
    It could also be a sign that you are low on oil.
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    What kind of oil are you using? Sometimes thick oil will cause a little bit of knocking on start up when its cold enough. Also, sometimes people get problems with anti-drain back valves in their oil filters. You might want to switch oil filter brands next time you cange your oil. Read this, it might help. http://www.dorianyeager.com/oilfilterstudy1.html
  5. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    I HAVE USED 10W/30 AND 20/50.
    AC DELCO FILTERS
  6. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    It’s got a K&N Oil Filter and Vavoline synthetic blend and I’m due for an oil change
