turndowns in cali on an emmissions k5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rix_Gotta_Blazer, Jun 28, 2002.
  1. Rix_Gotta_Blazer
    Rix_Gotta_Blazer 1/2 ton status
    Dec 13, 2001
    104
    Hollister, CA
    i am with out a doubt puttin a flowee on my '81 k5. the question is, can i just put a 90 degree turn down at the outlet as long as it is BEHIND the rear axle? i heard that as long as it dumps behind the rear axle, its legal. is this true in CALIFORNIA? or do i have to have pipes all the way out from under the body? thanx in advance.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Not sure if this is true for cali but here I belive the exhaust has to dump behind any passenger compartments(?) which on a K5 would be at the bumper....
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    I know we can't run turn downs here...they can't safely get the sniffer thing in to do the emissions test. At least that is what they tell you if you show up with turn downs.
    Rene
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'm in CA too, I've smogged a car with turndowns, and my truck has exhaust that exits in front of the rear wheels, they didn't have a problem with that either. As far as I know there are no smog laws concerning the exhaust system downstream of the cat. </font color>
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is a law in california that says the exhaust must exit over the rear axle and out the side behind the rear tire on any vehicle that has a passenger compartment which has a rear window that may be rolled down. This is so that the passengers don't get carbon monoxide poisoning from the exhaust fumes that will roll back into the rear of the vehicle when the rear window is open. As far as the smog crap goes, it really doesn't matter. You might find some shops that will not smog it because the exhaust isn't where it is supposed to be or because it is too hard to get at for the sniffer.
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Mine turns down about a foot in front of the axle, and I haven't been hassled about it. As long as the equipement is there most shops won't give you a bad time. Just be sure the turn down does not blow directly on the axle or brake lines, in the slow and crawly stuff you could overheat the fluids
  7. demon
    demon Registered Member
    Jun 6, 2002
    9
    Santa Fe Springs, Ca
    I wouldnt know, my blazer failed miserably. I didnt realize that the smog technicians would notice I was missing the complete exhaust system on my setup... rofl
    Gross Poluter /forums/images/icons/frown.gif
  8. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Mine turn down right after the axle. The tech did not even mention it.
