Turning 6" springs into 4" springs
Discussion in 'The Garage' started by 88jimmy4x4, Dec 20, 2003.
  1. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Turning 6\" springs into 4\" springs
    I currently have a 6" RC all spring lift. I will be installing 8" superlift springs in front and going to do a shackle flip in the rear so I will need 4" springs not 6".
    Can I remove a couple leafs from my current 6" RC rear spring pack to bring it down to 4"? (like maybe the overload and next smaller spring up)
    Any side effects?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Turning 6\" springs into 4\" springs
    haha, your truck is sweet, now you've got the bug and you are going farther. I'd say, remove the overload, and maybe one long leaf. Overload should be 1". Removing the overload would give you like 9" lift ni the back, maybe you could see how that works first.
  3. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I would suggest calling RC and asking them.
    Usually you dont want to remove the overload, that protects the springs from going into a negative arch and damaging them. Usually the one above the OL is where to start for one leaf, dont know about 2 leafs
  4. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    LOL, yup it never ends does it /forums/images/graemlins/rotfl.gif
    Well it all started the rear was lower than the front so I added some 2" blocks, now the front looks too low. So I got a sweet deal on some new 8" springs from superlift direct. Now I wanna get rid of the rear 2" block, add an echobit flip, but that would put my rear lift way to high. The RC springs are stiff (5 leafs plus overload) so I was hoping I could remove a couple leafs, make them ride better and decrease height at the same time /forums/images/graemlins/cool.gif If its still too high I will add a zero rate to the front. Dont wanna go any higher than that though.
    So remove a long leaf, not the short leaf right above the overload?
    I could call RC, but I respect you guys advice much more /forums/images/graemlins/grin.gif
  5. 88Silverado
    Mar 13, 2003
    2,664
    Hope they were the Superrides springs. Superlift is on the upper end of stiff springs. I have 4" superrides with UHMWPe strips in between and its still on the stiff side but im going to add different bumpers and a winch later so that may help. Im still thinking about removing one leaf from minee to help smooth things and level the truck.
    Heres the Springrate table
  6. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    i would think most of the lift comes from the main leaf with the others supporting it.hard to say what removing leaves will do till you put weight on them!
  7. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I turned my 6" fronts into 4" by taking out the veary botom leaf and not the one right above it but the one above that one. Now it rides better flexes more and leveled it out but it has way morebody roll(no sway bar) hope it helps
  8. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    y5mgisi, thats kinda what I want to do on the rear. Just wanna make sure Im not gonna cause the other leafs to weaken and/or break.
    I could buy some 4" spring packs, I just dont wanna waste the money if I can do this and gain a better ride, but if I have to I will.
  9. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    You really should be o.k. If you are real woried about it and want some reassurance, make some bump stops to stop them once they go alittle into the negative arch zone
  10. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I took out the over load leaf on my 2 1/2 skyjacker rear springs and it really tore them up. I did this put it all back together and went on a snow run. when I got home I looked under my truck and my rear springs looked like a huge S. I ended up putting the leaf back in but eventualy I had to buy new springs
  11. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I'd sell the 6 inchers...
    6 inch rear springs are always easy to sell
    or trade soemone for 4 inchers... /forums/images/graemlins/thumb.gif
  12. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    ORD has a 2 inch shackle flip that would allow you to use your 6 inch springs /forums/images/graemlins/thumb.gif
  13. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Your new avitar is much better Jeff!
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I liked the old one.
    The Echobit flip is more like 5-6", not 4. You're probably going to have to removed quite a few leaves to get it where you want it in that case.
    I have 6" Superlift front springs and an Echobit flip out back with stock 52s and my back sits higher than the front! And the 52s are from the mid-70s!
  15. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    well, i had gained a few pounds and so i couldn't downsize it enough to fit into 80x80 pixels and plus i lost some more hair and the glare from the flash it looked like a white blob anyway /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  16. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Oh ididnt mean to tel him to take the over load out /forums/images/graemlins/ignore.gif Just the one above it and the second leaf up from that one. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  17. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Dang I didnt know the echobit was that much. But if your superlift was 6" and the echobit was 5-6" how does it sit higher in the back? /forums/images/graemlins/thinking.gif
    So what do I need then some 2" lift springs? /forums/images/graemlins/confused.gif
  18. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    You havent even had it lifted 3months have you? You not gonna change the wheels and tire yet I Hope /forums/images/graemlins/thumb.gif
    Actually sound like you gotta trend going so why dont you just put a Zero rate and HD ORD shackles in with those 8in spings and have 10in all the way around /forums/images/graemlins/rotfl.gif
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I forgot about the ORD 2" lift. I'd go with that setup over the echobit and 2" springs.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just put your stock springs back in and use the Echobit. If it's too low, you can throw a zero rate or a block in. I wouldn't go to 8" springs. There's no reason, and you'll regret it later.
