Turning a flywheel
Discussion in 'The Garage' started by 80blazek5, Apr 10, 2007.
  1. 80blazek5
    80blazek5 Newbie
    Feb 13, 2006
    3
    Ga
    I'm putting a new clutch and rebuilding the drivetrain behind my 400sbc. Well I decided to resurface my own flywheel and I was told to turn it down till the hot spots are gone. I have turned down around .150" to .200" off this thing and the hot spots seem to be going away but it looks like i need to take around .100" more to finish. 2 questions: Am i going about this the right way? and when is it too thin? I don't believe this flywheel to have ever been turned before.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Wow, .300" sounds like WAY too much to me. I don't know the spec for minimum thickness of a SBC flywheel but that seems like way too much.
  3. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    There should be a minimum thickness number stamped on the flywheel. My concern other than the thickness is how your turning it. If make low spots in it by taking more out in one area than another it will shutter like a SOB when you start to engage the clutch.
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    actualy when thay cut them its setup like decking a head or block but with a good polishing job. thay dont take a whole lot off them when thay cut them. i do know racers cut them real thin to cut down the spinning weight.
  5. 80blazek5
    80blazek5 Newbie
    Feb 13, 2006
    3
    Ga
    I'm turning it in a lathe so no low spots. Runout was very minute when I checked it, somewhere around .003". So am I just supposed to turn it down till it cleans up or till the hard spots are gone? I figured if the hard spots were in it then the flywheel would not wear in correctly.
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I got mine turned to where it was just smooth again and have not had any problems
  7. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    A lathe is the wrong way to do it. The Flywheel needs to be ground on a surface grinder. The last one i got done cost me $30 and was ready in 45 minutes...
    Here is a pic of mine...you can see a swirl pattern rather than the finish you're getting on a lathe.
    I think this promotes better grip with the clutch disc than a lathe finish...plus it more accurately trues the surface up.
    Rene
  8. sweetk30
    Nov 1, 2004
    25,537
    536
    x2 for me. :D
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Actually, when a flywheel is new they are turned on a lathe. However it is VERY important that the face be parallel to the crank mounting flange. When a flywheel is machined in the aftermarket world it is done on a surface grinder rather that a lathe.
    If you've taken that much off you've no doubt ruined that flywheel. There is no minimum thickness on a flywheel other than when the springs in the clutch disc hit the flywheel bolts the flywheel is junk. There are exceptions to the rule though and those have to deal with hydro clutch set-ups on some stuff.
  10. 80blazek5
    80blazek5 Newbie
    Feb 13, 2006
    3
    Ga
    Well now thats confusing. I've talked to about 3 other machinist around here and they said they have been doing flywheels like that forever. I'm a machinist but I build aircraft parts (whole different world) From the looks of th pic, your flywheel was done with a rotary surface grinder. That means the surface finish is a 60 or better. My flywheel is close, around a 125. The flywheel might have been junk from the start as it was beat on pretty bad. The original surface was pretty scared up with a big step in it. I dunno what to do. I hate to buy a new one at $250 from centerforce, haven't checked autozone tho
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Flywheel resurfacing machines are there for a purpose. In the old days before there was a specific machine dedicated to machining flywheel people machined them on a lathe. However if you don't indicate the flywheel in properly from the crank mounting flange so that the clutch disc surface is parallel to the flange surface you will get one hell of a clutch chatter.
    EDIT: here is a link to the brand of machine i use at work. http://www.dcm-tech.com/dcm_products/flywheel_grinders.php
