Turning fuses keeps blowing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, Jun 2, 2002.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    Turn signals work fine until I put the truck into reverse. Once I put it in reverse it blows the fuse. What gives. Thanks for any responses.
  2. BB454
    BB454 1/2 ton status
    Apr 2, 2000
    134
    Gauteng South Africa
    Turning signals and reverse light switch share the same fuse - A short in the reverse light wiring could be the problem. If you are running additional reverse light you might want to check there first.
  3. Nate87k5
    77
    Phoenix, AZ
    Just one set of reverse lights. The originals. How do I find the short?
  4. Grim-Reaper
    7,385
    Atlanta
    I would start at the bulbs and work you way forward. If you have a trailer harness on the truck check that. THe tail light harness runs up the driver side frame rail. Just in front of the bumper it T and runs through the tail pan ( part where the hinges to the tail gate bolt too) to the passenger side. If the truck has ever been rear ended might be some wires damaged. The harness passes through a few holes in the tail pan. I would look to see if possibly the insulation has been worn off and it's grounding out.
  5. AmericanFreak
    AmericanFreak Registered Member
    Jan 6, 2002
    40
    Shillington pa
    Mine did the same thing it turned out to be the trailer wirng i got pissed and just cut them all off and taped em up problem solved now i cant tow anything "legally" but i still do not far though.
