turning radius.
Discussion in 'The Garage' started by eightyone, Apr 12, 2007.
  1. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    well, we all know that crew cab longbeds are not too good at turning. i was wondering if anyone offers and axle, or steering setup, or anyhting, that allows the front wheels to turn more. it seems like the front wheels just dont turn enough. i dont need much more, but just alittle more would be really nice. anyone know of anyhting?
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Switching to crossover steering makes a big difference in your turning radius but the down side is that you have to take your swaybar off.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    How is your draglink adjusted??
    Narrow your rearend.
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    True.
    But you can just fab in a swaybar.
  5. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    I did my entire senior design project in college about this. What I created was a cutting brake system for the rear. I used dual handle cutting brakes from CNC Brakes. Did a lot of work to match the right cutting brakes up with my current setup to have optimum brake force (14 bolt with 3/4ton calipers, Dana 60 front with 1ton calipers). With the OffroadDesign twinstick I can throw the rear out of engagement and drive with just the front wheels. The Detroit in my rear axle isn't a factor because there is no torque to the rear axle. If you have a selectable locker in the front, you can leave it open and turn even tighter by just snapping the throttle a bit and the inside tire pulls the truck right around. The cutting brakes also allow you to retain the factory brake system (still brake with all 4 wheels) when you use the pedal.
  6. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    offroad, i just whip the a$$ of the k5 around corners if i need to. it's easy, fun, and kicks up lots of crap for others to enjoy :wink1:. i have been known to do the same thing with my 94 xcab on the road, so it's an option for you, even if it's not perfect.
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I did ord xover and LOVE IT.. my truck never turned so well.. not even with stock suspension and 33's!!!!!
  8. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Is this for street/trai or trail only? If trail only you could get a front axle off a New Holland tractor. I think you might have to do a little bit of fabrication to make it work though.:rolleyes:
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    or dual front steer duce or mog axles....
    rear steer would make it alot better
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    what setup do you have now? there are lots of things you can do to improve it but at some point you have to accept that you are driving a truck.
  11. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I plan on doing exactly that to my trazer
  12. eightyone
    Apr 25, 2004
    292
    long island
    oh, wow. i guess i shoulda given more info. im running a 78 crew cab 1-ton. its got a dana 60 up front, and a 14 bolt with disk brakes int he back. and a 4 inch suspension lift, and 35's. this truck is mainly for towing. i am curently working on trying to get a cummins in it. i might wait for the new cummins' to come out tho. but anyways, this is not really for offroad. its mainly because backing up trailers in the yard at my dads shop is such a hassel. i might go for some crossover. i had that in my old blazer, and i loved it. thanks for the suggestions.
  13. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Something else that you can do, that hasn't been mentioned yet. Longfield CV axle shafts. They allow 45 degrees of turning (a good chunk more than stock). Expensive, couple grand for a set, but they're also indestructable. then you adjust your steering stops, make an nessecary changes to steering linkage/arms, and away you go, much better steering angle than stock.
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I used to run my crewcab without a front swaybar. You do notice the difference but I don't mind it.
    Also have a look at 99+ Superduties. That swaybar looks very simple, and they use crossover steering stock.
    I found the diference between a shortbox and longbox crew to be a make/break difference for real world around-town driving. A 150" wheelbase will just squeeze by in most cases, but the 165" often means a 2-point turn.
