Turning Radius
Discussion in 'The Garage' started by Emmettology 101, Dec 27, 2002.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    Anyone ever find a way to make their K5 turn sharper? I thought about trimming the knubs on the knuckles so they are shorter and allow more movement but I am afraid of having them turn to far and put too much stress on the u-joint.
    ANyone have ideas? The newer straight axle equipped vehicles seem to turn so much nicer and sharper.
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Run 31's and stock 15x7's... /forums/images/graemlins/grin.gif
    Rene
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Maybe you could ask that question to 1 FN HI K5 in a month or so /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    LOL, that would be nice! /forums/images/graemlins/smile.gif Reason I am wondering is if you go drive a new Dodge(or older like 94+) with a SFA, they turn very nice for such a long vehicle. Ours dont turn as sharp. The 1/2 ton Dodges use 44's up front so they should be very similar to our 44's and 10b.... I was wondeirng if maybe their turning stops are shorter? I would like to trim mine but how do you tell if you have gone too far and are putting too much stress on the u-joint without starting to blow them all the time?
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Rear steer would be nice, but too much $, labor and hassle. I like Rene's saying: K.I.S.S.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What did Steve do to the ORD Blazer to get it to turn so sharp?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Good question.. Hopefully he will see this and reply! /forums/images/graemlins/smile.gif
  8. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    I think the limit is tire size and backspacing of the rims. The bigger rubber has the potential to hit the springs, steering box, etc etc. Those are the real steering stops.
    I think you need to throw some 31's on your truck and then compare it to those Dodges...my buddy's 89 still turns on a dime, but the tires aren't that tall and they're on narrow 16.5" rims with stock backspacing...
    My truck probably takes an extra 10 feet to turn 180 degrees.
    Rene
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    On Emmett nothing hit(that I knew of), but on the 86, I am rubbing the inside of the driverside tire on the draglink! Once I readjust that I am going to see if it helps any, plus I may trim a little off the stops to see if it changes any.
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I wonder if a crossover setup would fix that?
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Mine rubs the drag link right now because it is out of alignment and turns farther one way than the other. But I bet Crossover would help turning radius! Come to think of it, I do believe the Dodges have a crossover type steering!
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I should have my crossover done this week and I was sort of wondering how tight I could crank the adjusters before I hit the steering box or if it wouldnt be an issue.
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Definately keep me posted!
  14. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    If all goes well, I'll be test driving it next weekend. Need to test out my new front bumper. /forums/images/graemlins/thumb.gif
  15. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    My 75 turns on a dime. There is a "stop" on each knuckle that limits the turning. Screw the stop bolt in and you will turn farther.
    If you are turning sharper in one direction than the other, you may need to adjust your drag link. There is an adjusting sleeve on your drag link that is supposed to help you center your steering wheel. If you adjust it too far, it will limit your turning in one direction.
    _____________
  16. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    When I went from stock steering to crossover steering I could not believe the difference. My lifted 89 turns sharper then Donna's stock 90 does. I didn't even adjust the stops when going to crossover and it made a huge difference.
  17. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    I'm with Wayne. My crossover made a huge difference on the turning radius. Never adjusted or grinded my stops either.
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Watson runs a twin stick 205 (so he can use fwd only) and has a turning brake hooked up to the rear axle (so he can lock up just the inside tire).
    For me removing the welded spiders would do wonders for turning radious.
  19. Greg72
    Mar 5, 2001
    15,682
    1,392
    642 Days to BB2018
    I cast another vote that crossover fixes the problem.
    My old draglink setup was the worst, U-Turns almost always required backing up at least once! /forums/images/graemlins/shocked.gif
    With the crossover steering, there is a MUCH tighter radius in addition to all the other beautiful things you get (no more bumpsteer, better offroad steering when crossed up, etc)
    You know it's funny, I remember people saying that crossover steering caused the powersteering fluid to overheat more easily. I think the reasons provided were that the steering setup allowed the steering box to move in a larger range of motion and pump more fluid around.....meaning that you were finally getting all the functionality out of the steering box. Kind of a neat "side effect" that proves more is really happening in the steering department!!!
    Crossover is great, but budget for an inexpensive external PS Cooler as part of the costs..... /forums/images/graemlins/grin.gif
