turning with front mini spool or EZ locker
Discussion in 'The Garage' started by trailblazr81, Sep 7, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Im thinking of adding a mini spool or one of those inexpensive easy to instal lockers into the front of my K20. It has manual hubs so I know I will be OK on the street, but will I be able to turn while wheeling? Its a full size long bed truck so I dont plan on doing much rock crawling or tight situations. Mostly mud, sand dunes, and whatever trouble I can get into where this truck will actually fit. I live in Hollister, CA so I will be playing at our local Off-Road area and Pismo Beach for some fun in the sand. I am just starting this build and so far have 383 stroker and 35" tires. Tires will probly stay under 38" since I would still like to be able to do the occasional towing and hauling.
    :dunno:
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I run a spool in the front of mine, it provides unbeatable traction but turning is a nightmare :doah: I run one hub unlocked most of the time and lock the other in when needed...but this puts all the pressure on one hub which I don't like.
    Also make sure to put in a power steering cooler, your pump is gonna be working overtime.
    Bottom line, I love my setup, wouldn't go back :D
    __________________
    '77 K5, Warn M8000, 402(TBI in progress)/350/205, 44 spool'd & chromo'd/14bff welded, 4"/36" Irok's
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Buy a LockRight instead of a minispool from Jeg's... they've got a decent price on them. I had a welded carrier in the front of my abomination when I got it... it was the first thing to go. Hard on the frame and didn't turn for beans. In high traction situations the wheel would turn but the tire would just distort... didn't turn very sharp like that. Not to mention what it was doing to the frame when I did that.
  4. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I have a mini spool in the front of my 3/4T BurbI LOVE IT!! I wheel with the hubs locked 99.9% of the time, Iv'e had to un-lock 1 hub 2 times to make a turn and that's it. I is DA BOMB!!!! in the snow, if I need to turn real tight I just turn the wheel and stand on it a little and it will allmoste pivot on the rear axle (I'm open in the rear).
    1 and only thing I don't like about it: I can't use 4WD on icey roads because even with 1 hub un-locked it will still let the front end "walk" real bad when turning to one side (the side with the hub locked in)
