Turnkey Gen III chevy crate motors / Petersons
Discussion in 'The Garage' started by djsblaze, Apr 23, 2004.
  1. djsblaze
    djsblaze 1/2 ton status
    Jul 7, 2003
    318
    Oklahoma
    Got my new Peterson's in the mail yesterday, there is an article about a company called "turnkey" that sells complete Gen III chevy blocks, 4.7, 5.3, 5.7, and 6.0. I guess they have "partnered up" with Advance Adapters to make these available. Article shows part 1 of the install into an 83 or so Blazer. Ive got the 5.3 in my Tahoe and love it. Apparantly, the engine and kit for the 6.0 runs around $5600 versus a RamJet 350 around $4800 to $5000. Can anyone think of a good reason why I shouldnt consider doing that swap into my 89? Oh yeah, new blocks will mate to most if not all older trannys. Food for thought /forums/images/graemlins/dunno.gif
  2. djsblaze
    Jul 7, 2003
    318
    Oklahoma
    Well, just saw the "piston slap" thread, so theres one chink in the armor. I dont have that problem with my 5.3 thought, and ive had 2 of em.
  3. antta99
    antta99 Registered Member
    Feb 7, 2004
    24
    windsor,ct
    Ive been thinking about putting a 5.7 LS1 in my Blazer.The article gives me a bit more incentive. /forums/images/graemlins/thinking.gif
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    The factory fuel injection, ignition system, and engine management on the Gen III engines is a nice setup. The modern technology has a lot of advantages. If you are afraid of CSK (I definitely wouldn't be) all you have to do is swap out the pistons to eliminate it. Good time to swap in a hotter cam and go fast.
  5. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I'd like to have one of those 5.7's out of the new GTO. I believe it is a Gen. III motor.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    If I spend 5600 bones on a motor it'll have more than 327 cubes.... /forums/images/graemlins/deal.gif
  7. k5james
    k5james 1/2 ton status
    Feb 25, 2004
    792
    San Diego, CA
    I believe the 6.0 is 364 cubes. Stock it will put out around 350 horses and about 390 ft/lbs. I'm leaning toward doing a lq9/4l65e swap into my blazer. There are better deals than turnkey though.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Might as well go LS1 if you're thinking about dropping $5600.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im going with a 6.0, will put out around 400HP with no emmisions crap on it. It will have the same output as an LS1 but with much more bottom end torque.
  10. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    1,001
    597
    Pueblo, CO
    6.0's are great, but there in the Garage sits an 8.1 fat block for mine. Injection and all! just got to wait for Howell's new harness and controller. That and some $$$$.
  11. k5james
    Feb 25, 2004
    792
    San Diego, CA
    Too bad that 8.1 doesn't have a whole lot of aftermarket support yet. That is one torque pig.
  12. ZooMad75
    Apr 5, 2003
    1,001
    597
    Pueblo, CO
    Aftermarket support may not be there yet, but its building. I just found a site yesterday at www.raylarengine.com They got the first aftermarket aluminum heads for the 8.1 and are working on new intakes too. Also Arizona Speed and Marine have a wicked looking 8.1 intake for marine applications that would pump up the tourque.
    But then again, 340hp and 455 ft/lbs of torque is plenty for my little 75! If the Howell harness is going to be a while I've had some discussion with people I know back at GM and it is possible to use the 8.1 Marine Controller with the stock harness. all it takes is money!!!!!!!!!
