Turns left sharper than turning right.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JROSS, Jun 11, 2002.
  1. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    After I replace my steering box I noticed that I had a sharper turning radius to the left than to the right. Is there a way to adjust this? (It could be I just didn't notice before) It seems as if I have an extra 1/2 to full turn of the wheel to the left than the right. Also, The steering seems to be tighter with the new box. I also noticed that the power steering pulley has two grooves for belts and I only have one belt on, could this be why my steering is tight. /forums/images/icons/confused.gif thanks for the help.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    There are stops located on the knuckles. Check to see that if at full turn these are both contacting the axle tube. If they do then just adjust the stop on the passenger side and see if you get full turn back.
  3. JROSS
    Oct 12, 2001
    281
    Redding, CA
    It doesn't look as if contact is being made. The stops don't show any signs of contact.
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    You should be able to adjust your draglink to get equal steering left and right. Once you have that adjusted OK then adjust the steering stops to suit.
    Rene
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You have to adjust the steering so that the steering box is centered. That is, the internal gears are exactly halfway between full left and full right when the tires are pointed straight ahead. You can adjust this from the drag link, as stated above. Once you have it set correctly, then you can adjust the steering wheel so that it's oriented properly. /forums/images/icons/cool.gif
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My stops didn't have any signs of contact...at full lock, they never touched the axle tubes...maybe this is why my steering box is in such bad shape. I bought some new bolts to use for the stops...I think they are a 1/4" longer, thread size is 3/8-24.
  7. JROSS
    Oct 12, 2001
    281
    Redding, CA
    Thanks for the info on the steering issue all. Anyone have any coment on the 2 belts for the power steeing pump? /forums/images/icons/smile.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    One belt would normally go over the P/s pump and to the air conditioning. Apparently you don't have air conditioning so you don't need it.
