turns left under breaking
Discussion in 'The Garage' started by general blaze, May 10, 2006.
  1. general blaze
    general blaze 1/2 ton status
    Sep 4, 2005
    128
    ca
    ok when i am driving my truck on the street everytime i break it turns hard to the left. when i let off the break it jams back to the right. anyone know what is causing this. my breaks look good.
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    It is most likely your steering because when you slam on the brakes it compresses your front suspension and causes your steering geometry to change. You might be able to see what i mean by pushing up and down on the front of your truck while looking at your steering wheel (steering wheel unlocked) or your draglink, they should move back and forth.
  3. general blaze
    Sep 4, 2005
    128
    ca
    i will give that a try thanks
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    also low tire pressure can cause this
  5. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    swerve!...
    A rubber brake hose that is collapsed internally,or restricted ,will cause the same symptoms,as will a siezed caliper that does not apply pressure to the pads on one side,or a dented steel brake line..it'll swerve to the side that the brakes are working correctly on,then back the other way when you release the brakes..rusty caliper bolts and slides also can cause this..aligenment problems can too...(toe in and caster,and ball joint/tie rods worn or loose)..
    I had one truck that did this and I tried everything I just listed,and it still did it!:mad: --I finally figured it out..one front tire was a different brand,same size was MARKED on the tire as the rest,but was a different brand--it turned out it was 1.5" larger in diameter,and was a 6 ply "C" rated tire,and the other 3 were matching 4 ply "B" rated tires!..:doah: ..changed the tire to one that matched the other 3,and it was gone!..wish I looked there first...wasted 100+ bucks and lots of labor!..:(
  6. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    You need to look at your right side front brake like diesel4me said.Unhook your right rubber line at the caliper,it should drip like crazy if it doesnt it most likely is plugged up.If that checks out ok then look at the caliper to make sure it can move freely!
  7. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Check for a stuck caliper or collapsed hose.....
  8. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I agree with those who say its the brakes.
