TV cable ? 700R4
Discussion in 'The Garage' started by crwln73, Jan 22, 2003.
  1. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    I did a search and all I can find is how to adjust it.I want to know is how hard is it to change?Do you have to drop the pan? /forums/images/graemlins/1zhelp.gif
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    no you dont have to drop the pan
    there is one bolt on the tranny and unhook it from the carb
    then adjust it,
    thats it
  3. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    What does the end of the cable attach to at the tranny end?
  4. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    Re: TV cable ?
    no, just unbolt it from the trans, pull it up until it stops, unhook it from the rod in the trans(you may whant to put needel nose vice grips on the rod to make it easier to install), unhook from the carb and braket and its out. dont forget to ajust the new one.
  5. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    its a hook type thing in the trans
    unbolt it and you will see it
    sorry i cant be of more help
    but im a newbie
  6. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    Look here.....
    http://www.thirdgen.org/newdesign/tech/detent.shtml
    Look at the pictures, it is the same on a blazer.
    You do not need to remove the cable from the trans to adjust it.
    Push in the metal release for the cable, pull cable all the way back in, turn thottle to Wide Open Throttle and the cable will pull out to the correct setting.
  7. joker89blazer
    Nov 21, 2001
    130
    Never mind.Guess I should read before posting.
    To replace...
    The cable housing is bolted to the trans with one bolt.The inner cable hooks onto a rod inside trans.
    1]Unbolt cable
    2] pull up on the cable so that you can clamp a small pair of needle nose vicegrips on the rod
    3]unhook inner cable from rod, leave vicegrips in place to keep rod from going back into trans
    4]hook new inner cable to rod,remove vice grips
    5]bolt cable housing to trans
    6]install cable to throttle asem.
    7]adjust
    /forums/images/graemlins/thumb.gif
  8. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    Thanx !! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
