TV cable on a 4L80E?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Aug 13, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I could've sworn the last time I looked at the purchase sticker for my grandfather's 1992 K2500 it said it had a 4L80-E...But the other day I looked at the engine and it had what look to be a TV cable that is the same as on my old 700r4...Is this cable a TV cable or does it serve a similar purpose as the th400's kickdown cable?
    Chris
  2. dyeager535
    26,979
    I would have to think that if its a 4L80E that late, the TPS would be used for "kickdown". No reason to use a mech cable on an electronic tranny, I thought that was the point! : )
    I'm thinking the truck has a 4L60 then??
    Maybe a typo? Check the RPO codes (glove box, right?) and look for the codes starting with "M". 80's GM vehicles RPO tranny codes started with M, so I would imagine a '92 would as well.
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    A 4-L80E will not have any kind of kickdown cable. It is all controlled by electronics. ( ECM, PCM, TCM)
    My .02,
    John
  4. 88streetblaze
    88streetblaze 1/2 ton status
    Jun 27, 2001
    314
    middle of sticks, oklahoma
    didn't they make non-electronic versions of both the 4l60 & 80? or just the 60
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Just the 4L60. The same thing as a 700R4. The 4L80, IIRC never has had anything but electronics.
    John
