TV Cable or detent cable on 89 700r4
Discussion in 'The Garage' started by MudFlap, Dec 21, 2004.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I broke the clip off of my TV cable where it attaches to the throttle bracket and I think that I will have to just replace the whole cable, are there any other options?
    Also does it have a detent cable? Because the only 2 cables that I see are the throttle cable and the TV cable. But when I searched on gmpartsdirect.com all that I could find was a detent cable, is this the same thing as a TV cable?
    Thanks.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A 700R4 only has a Throttle Valve cable (TV Cable). I think you will probably need a whole new cable. They are not terribly expensive even at the Dealer.
    I paid $40 for my TV Cable from the GM Dealer. I would recommend you get a GM part, don't settle for some cheap crap. That cable controls the entire transmission and if it isn't set right you can fry the tranny. 700R4 are big $$$ to rebuild too. The extra $10-15 for a good cable is worth it.
    Harley
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A Pioneer brand cable is just as good as a GM one and is available at your local parts store.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they make a kit to fix the broken end, price is $2 and is a very easy fix. i know i can get them.
    i picked up a new cable from my dealer for $20
  5. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I appreciate all of the replies, but I am not concerned about buying a new cable, that is what I had planned on doing, but I can't find a TV cable to buy, all that I can find is a detent cable. Is this the same thing? I am assuming that it is, because the only two cables that I see are my throttle cable and the TV cable.
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    It is a TV cable but the parts catalogs might list it as a detent cable since it does have a some similar functionality.
    I would assume that if they only list one cable it is the right one. 700r4 tranny's don't use a detent cable.
  7. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    That is what I figured. Thanks bud.
