TV cable question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trigger, Jul 16, 2003.
  1. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    How much slack is suppose to be in the cable? If I push it from one side to the other (towards each fender) it has about 1" of movement in it.
  2. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    can i add to this.
    if the tv cable is not adjusted properly, would it
    cause the truck not to go into overdrive ?
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    trigger that is too much slack & scrappy i believe that could cause it not to go into OD. my tv cable has no slack in it when the engine is not running ( or the throttle is closed).
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Usually the TV cable is set to where there is 2-3lbs of pressure over the base idle pressure. As the cable is pulled out (as the throttle is open) it applies more progressive pressure too the clutches. No tension on the cable will allow the clutches to slip under load and burn them up really fast.
    A pressure gage makes setup real easy. Heres a link with more info.
    TV Cable setup
    http://www.73-87.com/garage/tvcable.htm]TV Cable setup_2
