TV Cable???
Discussion in 'The Garage' started by Ledzoso, Feb 28, 2005.
  1. Ledzoso
    Ledzoso Registered Member
    Feb 11, 2005
    15
    Midland, Tx
    Maybe a dumb question...new to the 700R4...What is a TV cable? Another thread I posted about new intake came with several replies about adjusting the TV cable and how much of a pain it is. Can some one give me an over-view on this situation? How to adjust it? Thanks....
  2. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    check out bowtieoverdrives.com . They helped me out alot when I did my 700r4 swap in my 75 years ago. they have a great tv cable and adapter that adjusts and mounts on the carb. Plus they work with you on the adjustments so you don't destroy your tranny.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Adjusting your TV cable isn't a pain it is very easy. Not adjusting it is a pain because running one out of adjustment will kill your tranny.
    I rember your other post.
    Your stock cable should work with a TBI adapter. You may have to do a little fabrication or bend on the cable bracket but it should be long enough. read that TV made easy link in above post so you understand how important the TV cable is to your trans.
    There are a lot of sites that have info on 700R4 and TV cables just do a search on 700r4 TV cable adjustment.
