Tv cable
Discussion in 'The Garage' started by adamforsythe, Jan 18, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Tell me what the cable does. I believe it just kicks the tranny down to the next lowest gear when you are at WOT.
    Adam
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    It combines the functions on the heritage trannys (TH350,TH400) of the kickdown cable and the vacuum modulator.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    that is correct for a th350, (which is called a kickdown cable), but for a 700r4, it overates the throttle vavle and adjusts shift points and firmness acording to where the throttle is. kinda like a Throttle position sensor for the tranny.
    if you don't hook it up or is not ajusted correctly, it will kill your tranny FAST. the more missadjustment, the faster it will kill it.
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    From experience, the 700R4 is extremely sensitive to TV cable adjust(do it once a month if it feels reassuring) and ATF level.
  5. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
  6. 10pax
    10pax Registered Member
    Apr 7, 2005
    95
    Ft Bragg, NC
    What about a shift kit
    Does a shift kit affect this equasion?
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    So if I do't have it hooked up on my TH350 it will kill it??????????????
    Adam
  9. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Adam, what tranmission are you enquiring about?
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a th350 does not use a TV cable, it uses a kickdown cable. so no it won't.
    what i said is only true on trannies that use a TV cable (700r4, 4T60, etc)
  11. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I see..........my bad.
    Adam
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Sorry 'bout that, when you started the post with "TV cable" you automatically programmed "us" to 700R4.:D
    Like my engine?:haha:
  13. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Yea your engine is colorful.
  14. swissk5
    swissk5 Registered Member
    Oct 18, 2004
    7
    Switzerland
    once again i am saved from wreckage and severe distruction by you wonderfully knowledgable guys on ck5. everyone over here is telling me that my 700r4 has a kickdown cable.. i just built in a mpfi and my k5 won't shift right anymore, it must be this! thanks alot for the link to powerdemon as well, that'll teach em.. if only people here knew english.
