TV or not TV that is my question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Khi5in, Mar 19, 2002.
  1. Khi5in
    Khi5in Registered Member
    Mar 19, 2002
    46
    Medford Massachusetts
    Let me say this. I just bought a 86 k5 4x4. The tranny is a 700r4. I had to replace it. This thing started as a vibration in second gear then a delay in reverse then was sitting in drive at idle and it felt like i was in an earthquake. the whole drive train was shakin all over. I ran into a good tranny and changed it. Now none of those other problems but this thing slams into second gear hard. I ws told by numerouse people it was the TV cable. So I found the online instructions on adjusting it. Played with it some more and it got a little better. I guess after all this talk what i need to know , is the tv cable my problem or something else. I can't keep diving like this i'm afraid i'm gonna wipe out the tranny. Any advise or help will do.
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well, if your TV cable is adjust correctly and it still shift hard, you may try loosening it up like 1 "click" and see if that helps...Don't loosen it too much though or your toast your tranny...Does the tranny have a shift kit...? Just a few things to think about while the tranny gurus round up their answers...
    Chris
  3. Khi5in
    Mar 19, 2002
    46
    Thanks for the advise. tried loosening it and it did get a little better. but i don't want to over do it like you said. No shift kit but it feels like one. only 1st to 2nd hard shift.
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Is it hard are part throttle, full throttle, no throttle, or all of the above...My old 700r4 was a super hard shift between from 1 to 2 but it was mainly when I gunned it most of the way through 1st then let off, then it was like "BANG!!!" But it was a nice shift at full throttle and acceptable at part throttle...Try a fluid flush and filter change...that has help a few of my friends in fixing their sick 700's
    Chris
  5. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    My 85 700r4 does that hard 1-2 shift also, could it be normal? Chris
  6. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    where are these instructions to adjust the "tv" cable ?
    i know my tranny is good , but she kinda slides into gear , but not a slipping glide , so someone told
    me to adjust the cable . i just not sure how to do it right with out messing it up.
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
  8. Khi5in
    Mar 19, 2002
    46
    Thanks for all the input guys. I took this truck to a gm tech I am friends with. He said the shift points are correct and i f i adjust the cable any more i might have more problems. He thinks there is a kit in this . All I can do is wait to see if it gets worse. so far it hasn't got worse but I wish i knew if it was right or not..
    To answere your question chris- good shift at full throttle , acceptable at half but real smooth if i let off just before the shift and got back on.
  9. shoeless
    shoeless Registered Member
    Nov 1, 2001
    99
    N/A
    I just had mine rebuilt about two months ago and is does the same thing. Nice shift full throttle, but hard shift at part throttle, but the guy put a shift kit in it. Mine always shifted hard before it was rebuilt though.
  10. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    I just had mine rebuilt also, it to slams into second. The guy who rebuilt it told me it was like that because he put a corvette servo and bands in it. I'm not sure i like it but but it makes the big ol' girl feel like a sports car/forums/images/icons/smile.gif
  11. Khi5in
    Mar 19, 2002
    46
    I hear Ya. i'm not sure i like it but it does go pretty good. hope it knocks the rust off so there will be less to do when it gets warmer! LOL!!!!!!!!!
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can tell if it's too loose very easily. Loosen it, then drive it. Accelerate normally until it shifts to 2nd, then floor it. It should downshift. If it doesn't, it's too loose. If it does downshift, it's fine.
  13. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    this is off subject a bit, but i was really wondering: i just swapped a 700 into the 79k15, i did away with the 350. i love the low first, and the overdrive. but why did they do away with the vacuum modulated shift points. this tv thing is a pain in my a$$. its been such a piece of $ |-| ][ ']['
  14. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't know. I've thought the same thing...but once you get the TV cable set, you're good, no more messing with it from there.
    Make sure it's not binding or anything.
